Magnetic ride shock failure
Old Oct 27, 2014 | 06:55 PM
StingRaycer's Avatar
StingRaycer
Default Magnetic ride shock failure
I have had my C7 for over a year now. I began hearing a groaning/pop sound in the front end about a week ago at parking lot speed, especially turning right. I took the car to the dealer last Tuesday. They had a hard time finding it at first. They found the right camber adjustment nut loose. Tightening it did not help and then they discovered the mag shock was oily shiny. A seal on the shock had failed and oil covered everything in the wheel well, apparently worked its way into the camber adjustment bolt and allowed it to loosen. All is now repaired/replaced and tight with extra nut locked on as of today and Bowling Green had the faulty shock sent to them immediately. Thanks GM for competent work and to Bowling Green for their tech support.
Old Oct 27, 2014 | 07:00 PM
Not So Fast's Avatar
Not So Fast
Stuff does happen but if they took care of it and YOUR HAPPY that's all that matters
NSF
Old Oct 27, 2014 | 07:24 PM
*C7*'s Avatar
*C7*
St. Jude Donor 05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Glad everything worked out for you but I doubt the shock oil caused the camber bolt to loosen.
Old Oct 27, 2014 | 07:52 PM
StingRaycer
In that case everybody better check their nuts...and bolts
Old Oct 27, 2014 | 07:53 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
In prior gen Vettes, the camber nut has been somewhat loose to begin with. I also doubt it came loose from oil on it. This is the first I've read of a MSRC shock going bad on a C7 tho. Glad it's fixed.
Note: this was posted by "Bill Dearborn" recently: "You could also have worn rear control arm bushings that could be causing issues. Another thing to check is to see if the LCA camber adjustment cams are tight. A lot of alignment guys don't torque them down enough (this is one of those areas where I am a tighter is better type of guy and I use wrench extensions to get them tight)."
fr. here in C6 Gen, post #11: https://www.corvetteforum.com/forums...teinjager.html
Old Oct 27, 2014 | 08:24 PM
Bucknut2006's Avatar
Bucknut2006
Had a MSRC go bad on my CTS-V after only 5000 miles. Was discovered when getting performance parts put on the car. Made me a little nervous about getting another car with them.
Old Oct 27, 2014 | 09:49 PM
fdxpilot's Avatar
fdxpilot
As opposed to a shock failure on a conventional suspension? These not only fail on occasion, but also need regular replacement.
I'm assuming Caddy replaced your shock under warranty.
Old Oct 28, 2014 | 04:30 AM
Second Vette's Avatar
Second Vette
I just checked my Nuts. They're still there.
I'll check my Bolts tomorrow.
To Magnetic ride shock failure
