SD card help
Old Nov 8, 2014 | 11:42 AM
mustard's Avatar
mustard
Default SD card help
My SD Card is stuck in my 2015 PDR slot. How can I remove the card or remove the PDR itself? Thank you
Gene
Old Nov 8, 2014 | 11:58 AM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Did you push it in? It's held in by a spring loaded latch
Old Nov 8, 2014 | 12:44 PM
Jay_Davis's Avatar
Jay_Davis
Don't know how that would have happened, but my first option would be to use a needle nose pliers to try to pull it out. After that you are probably disassembling the dash.
Old Nov 8, 2014 | 01:42 PM
bbrown450's Avatar
bbrown450
I would not do that it will tear apart..if you cannot get it to eject by pushing in on it.Go to the dealer...make it their issue
Old Nov 9, 2014 | 12:10 AM
mpuzach's Avatar
mpuzach
Something doesn't sound right here. Why would you want to remove the actual PDR?
To SD card help
