Glass Cleaner???
Old Nov 10, 2014 | 09:46 PM
Coulson T's Avatar
Coulson T
Default Glass Cleaner???
This is probably been asked a number of times..but I can't find anything on it....I've tried a number of cleaners and been through the chore to find the proper cloth to use...but I'm still finding the interior windows with vinyl off gas and the ever present microfiber lint in the glass....driving me nuts..
Pardon me if this POs anyone...
Old Nov 10, 2014 | 09:50 PM
Glen e's Avatar
Glen e
take a microfiber towel and wet it with 25% rubbing alcohol and 75% water....done....
Old Nov 10, 2014 | 09:51 PM
HDBADDOG55's Avatar
HDBADDOG55
one part rubbing alcohol, 3 parts water. Mix in spray bottle. Spray onto clean cloth, apply to your glass, wipe dry with dry micro-fiber cloth or paper towel. Haze will be gone.
Old Nov 10, 2014 | 09:53 PM
Bill B 1's Avatar
Bill B 1
Adams. they offer a very good glass cleaner and MF towel specifically for glass. Works great, no lint or fiber discharge.
Old Nov 10, 2014 | 10:09 PM
RedC7AZ's Avatar
RedC7AZ
The better quality Micro Fiber towels don't leave lint and work dry when removing the film.
Old Nov 10, 2014 | 10:12 PM
Glen e's Avatar
Glen e
exactly - buy them from the place that supplies most vendors with the towels
microfibertech.com - a good all around towel is a 530-575 GSM grade...
Old Nov 10, 2014 | 10:13 PM
John Ulrich's Avatar
John Ulrich
Invisible Glass and the 2pk green glass cleaning towel Walmart sells in the automotive dept. Best I've found.
Old Nov 10, 2014 | 10:15 PM
-CM-'s Avatar
-CM-
I second this. And spray the towel, not the glass.
Mira cloth works well, also.
Old Nov 10, 2014 | 10:29 PM
Rave's Avatar
Rave
I get excellent results using Mira Fiber Cloths as well. I got mine here:
http://www.southerncarparts.com/ulti...html?infoBox=8
Old Nov 11, 2014 | 07:04 AM
C7Joy's Avatar
C7Joy
The manual actually mentions using damp microfiber on the interior glass for the first six months to reduce haze. Spiking that with some rubbing alcohol would probably make that more effective.
Old Nov 11, 2014 | 09:46 AM
Kracka's Avatar
Kracka
Stoner Invisible Glass. Available at most auto parts stores, Wal-Mart, etc.
*edit*
Yes, it is tint-safe. I've used it on numerous cars with various types of window tint.
Old Nov 11, 2014 | 09:50 AM
dvilin's Avatar
dvilin
Old Nov 11, 2014 | 10:31 AM
Larry/car's Avatar
Larry/car
GM glass cleaner and high quality paper towels work great.
Old Nov 11, 2014 | 10:57 AM
Varmit's Avatar
Varmit
St. Jude Donor '08
micro fiber towels: get the ones from S. Korea and not China.
Old Nov 11, 2014 | 11:06 AM
VETJAZZ's Avatar
VETJAZZ
Wipe the glass down with Mira Fiber Cloth lightly dampened with distilled water and dry with micro fiber.
Old Nov 11, 2014 | 12:05 PM
CRABBYJ's Avatar
CRABBYJ
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
What I use now as I got three cans free at Carlisle. Pretty good stuff.
But this one is the best cleaner I've ever used, even with Bounty Towels.
Old Nov 11, 2014 | 12:33 PM
SSTG's Avatar
SSTG
Alcohol and water will work but does smell pleasant.
Meguiars glass cleaner is concentrated, works very well and is cost effective.
Not only is a quality Microfiber needed so that lint is not left behind but so is the removal process, be sure not to bunch the towel between your fingers as this will cause streaking. Finally, clean the inside of the windows one way as in Vertical or Horizontal and the out side the opposite so you know which one has streaks on your final inspection.
To Glass Cleaner???
Old Nov 11, 2014 | 12:38 PM
Glen e's Avatar
Glen e
never had that problem as it evaps easily....no residual smell at a 25% mix
Old Nov 11, 2014 | 01:39 PM
bevo_87's Avatar
bevo_87
Glen, can you use this same mix on ceramic window tint? or on the review mirror and driver side mirror with that coating on it?
Old Nov 11, 2014 | 01:40 PM
Glen e's Avatar
Glen e
dunno...ask the mfr...easy online email question, I assume
my guess is you'll be ok, 25/75% ISP mix is really tame for everything....
