tire pressure sensor question?
Old Nov 13, 2014 | 01:46 PM
C2367's Avatar
C2367
Default tire pressure sensor question?
I have a set of Micky's mounted on 18X9.5 Z06 Style aftermarket wheels with pre 2010 TPS's on them. Would like to know if I would need to replace them for the correct TPS's for a 2015 C7. Would the car go into Limp mode if I use as-is. The drive is about 50 miles each way to California Speedway / Dragway (1/4 mile). I would only be using them to come and go to the strip and then replace with the stock tires. If the light goes on then I could be OK with that as long as the car functions fine. Thanks for any help.
