My lucky 7's
Received 19,303 Likes
'20-'21-'22-'23-'24
Those are two really sweet Vettes you have.
Received 7,752 Likes
CORVETTE TODAY Host
St. Jude Donor'15
^^^ +1
Nice pair for sure.
Beautiful cars!
Received 4,505 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Sweet!
Very nice.
1967, my favorite year Vette. Might have one someday along with a bigger garage and winning the lotto. Convt, redlines and sidepipes, Priceless! Headrest option too. Dick
Virtual George
Navy
The 67 was my only frame off I ever did. It is an number matching L79 and that is the original color. Beyond that, It looks very original but I did a few upgrades to it:
Fame Powder Coated
New gas and brake lines
New Gas Tank
New Brake Calipers
Power Brakes added
5-speed Tremec Transmission
Variable ratio Power Steering Added
Aluminum A-arms added to front
Coil over Shocks on front
Sway Bar added to rear
Heavy Duty radiator with Black Ice coating
Build in hidden fan shroud with large electric fan using Dakota Digital electronic controls
Seven blade manual fan also with stock shroud
High Flow Water Pump
Distributor converted to electronic
Vintage Air added
Offset rear Trailing Arms
Slightly wider Power Coated wheels
Red Line radials
Interior has a lot of sound deadening, even under the dash and in the doors
New wiring harness under hood and under dash.
Speedometer converted to electronic
Tachometer converted to electronic
Oil Pressure meter converted to electronic
Amp Meter converted to Volt Meter (looks stock)
New improved speaker added
Headrest Seats added
Cloth Convertible top added
Quick Release Hood Hinges
Better headlights
C3 Steering wheel, covered in Leather
Tilt Steering Column
Drives like a dream.
Virtual George
Fame Powder Coated
New Gas Tank
New Brake Calipers
Power Brakes added
Vintage Air added
Red Line radials
Better headlights
Virtual George
