Flash drive access
Old Nov 24, 2014 | 04:39 PM
Pete V's Avatar
Pete V
Default Flash drive access
Hi folks,
I need some advice on how to access the flash drives in my 2015 C7.
There are 3 drives, it seems I can only display one at a time and if I have a flash drive in the port behind the screen ,that one takes precedent over the others. Is this normal ,I read in the manual that 2 would be usable.
I am confused on the proper order and use of these drives.Any assistance in clearing this up would be greatly appreciated.
Sincerely
Pete V
Old Nov 24, 2014 | 07:59 PM
Klyde's Avatar
Klyde
Repeatedly pressing the "Media" button should step you through all the USB and SD cards.
Old Nov 24, 2014 | 08:49 PM
Pete V's Avatar
Pete V
Thanks for your response, I think I tried that,but I will try it in the morning.
Thanks again
Pete V
Old Nov 24, 2014 | 08:52 PM
Pocket Aces's Avatar
Pocket Aces
I'm just wondering why you have more than 1 flash drive attached?
Old Nov 24, 2014 | 09:17 PM
Pete V's Avatar
Pete V
I just went out to the garage to try scrolling through the media button,
Unfortunately it didn't work,I can only get one drive at a time ,all the ports seem to work but only if there is only one flash drive in at a time. I'm not very good with these electronics .Hopefully someone at the dealership can help.
Pete V
Old Nov 24, 2014 | 09:18 PM
Pocket Aces
Again...why do you have more than 1 flash drive attached?
Old Nov 24, 2014 | 09:21 PM
Pete V's Avatar
Pete V
I wanted to have different types of music on each,if that's not possible I'm
OK with that but I want to make sure I don't have a problem.
Pete
Old Nov 24, 2014 | 10:10 PM
vettnutt's Avatar
vettnutt
No problem. You can only access one drive at a time.
Old Nov 24, 2014 | 10:14 PM
bbrown450's Avatar
bbrown450
Hey different strokes. I have a 32 gig SD, another 16ig SD in a USB Dongle (Console) and I use a 16 gig USB (behind screen) for wifes music. I name each device based on what slot they are in so when I toggle thru I can see which one is active.
Also for those that have not figured it out if you toggle DIC to "audio" you can browse all of your devices by Artist or album or genre.....
Old Nov 24, 2014 | 10:15 PM
Pete V's Avatar
Pete V
Vettenut,
Thanks I have been searching the manuals but could not find anything to answer this question
Thanks again I feel better now!!
Pete V
Old Nov 24, 2014 | 10:20 PM
Pete V's Avatar
Pete V
Bbbrown450
Can you toggle through the 3 Flash drive ports or can you only access one at a time
Pete
To Flash drive access
