I've been reading on some threads about the 2015 C7 having A8. Does that mean it has 8 gears? What would the benefit of that be? Obviously I know nothing about car mechanics but since I have a 2015 C7 on order I would like to know more. Thanks
It's not just that the new automatic has more gears, but that it is a new design. It is said to be faster shifting, better logic to be in the gear you would prefer, and uses steering wheel mounted shift paddles in manual mode.
The only time I ever put my C6 in manual mode was if I needed a little extra boost to pass someone - a salesman taught me that.
What is the benefit of having more gears? Say before (C6) I would switch into manual mode, downshift to 5th, pass the car, go back to 6th, then back into automatic mode. So with A8 transmission would I shift from 8th to 6th?
The A8 is designed for the massive torque and hp. of the Z06 so it should be a more robust transmission than the A6. Having more gears should make it more responsive to just about any situation--assuming the software is right. I have a 9 speed in my 2014 Jeep Cherokee and its a great transmission, but it had a lot of teething problems requiring multiple reflashes of the transmission and engine CPU. I haven't heard anything like that with the A8 in the Corvette. You also have to be doing about 85 to get it into 9th gear in the Jeep so its not much use in normal driving.
I've been reading all kinds of positive impressions of the A8. Things like people who wouldn't even consider an automatic saying that they would opt for it. And literally all of the automotive press is raving about it. Just about every user testimonial I have read on forums is also extremely positive. Essentially its a home run.
All of this combined has made my transmission choice a very difficult decision. 2 months ago I would have laughed and replied, "M7 all day long". Today i'd probably opt for that A8.
