Carbotech brake pads coupon Z28
#861
Supporting Vendor
St. Jude Donor '11,'13
Open Saturday for QUESTIONS and of course ORDERS... Give me a call at 216-780-8825.
If you have no questions and know what you need, order direct 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save 5%.
F: Base/Z51 CT1001
R:Base/Z51 CT1718
F: ZO6/GS Iron rotor CT1405
R: ZO6/GS Iron rotor Ct1718
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#862
Supporting Vendor
Carbotech brake pads 100% made in the USA!
Use promo code z28 at check out and save $$ or call us direct at 216-780-8825 and save $$.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#863
Supporting Vendor
Carbotech performance brake pads including low dust performance street pads. 100% made in the USA!
Street pad is the 1521 compound low dust 100% non-corrosive will not harm your wheels or paint.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#864
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#865
Supporting Vendor
Friday order direct 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save 5%. If you do not know what you need call me at 216-780-8825 or email sales@ampdautosport.com
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#866
Supporting Vendor
The street pad is the 1521 compound LOW DUST 100% NON-CORROSIVE WILL NOT HARM YOUR ROTORS,WHEELS OR PAINT. Order direct 24/7 at http://ampdautosport.com/brake-pads/corvette/ Use prom code z28 at checkout for your 5% discount.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#867
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#868
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#869
Supporting Vendor
SHOP FOR YOUR PERFECT BRAKE PADS NOW!
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#870
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#871
E-Ray, 3LZ, ZER, LIFT
Received 9,625 Likes
Hope you have better luck than me as I tossed those after 900 miles and bought Carbotech 1521s!
PS: You'll probably be told by a Moderator when the Post is removed! Happened to me when I first joined!
Adam@Amp'dAutosport.com (07-19-2018)
#872
I followed this thread under C7 Genetal Discussion. Maybe the Vendor is posted in the wrong area?
#873
Nope as I was told-if a Vendor starts a Thread in any section, General tech etc you're not to post other products. I did it on something other than brake pads! That was my C6 Z51 where you did not need ceramic brake pads as the OEM pads were not that bad!
#874
My Bad! I thought General Discussions were just that and that Vendor Threads were segregated.
Buy CARBOTECH!!
Buy CARBOTECH!!
#875
When it happened to me when I started did not realize it was a vendor started thread! Like this one, how would you know unless you tried to fine the 1st post. However if you get a PM from a moderator I'm sure they will explain!
See you're a recent member. Don't let my comments stop you from posting as it's a great way to get quality info and post an opinion. However like anything on the Net, best to review all comments and make your own decision. Often conflicting comments but that gives both sides of an issue!
#876
Thanks for the correction. I was just surprised that a vendor could own a thread on the General forum.
I'll be more careful next time I comment on a general topic.
#877
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#878
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#879
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#880
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
