Launch Control
Old Nov 29, 2014 | 09:29 PM
Hdhuntr01's Avatar
Hdhuntr01
Default Launch Control
I decided to try it out and I may have done something wrong here but I really don't see the performance purpose. Now to explain. I did a launch control and did a quite impressive burn out but the problem is that if I had not eventually let off the throttle, I would have simply burned my tires down to the rims. LOL I was on a standard asphalt road and outside temp was about 65 degrees. It just didn't grab traction so I had to let off a bit then romp on it again to get moving. My 2014 A6 has around 3000 miles on it so the tires are still in great condition. The roads were not at all wet. Has anyone experienced the same situation? Any suggestions?
Old Nov 30, 2014 | 02:51 AM
VegasAlleycat's Avatar
VegasAlleycat
I just completed the Ron Fellows Performance Driving course a few days ago and the instructors demonstrated launch control. They said that if you didn't mash the throttle in fast and let the rpm stabilize and/or didn't pop the clutch out fast enough that the computer would disengage launch control mode and you would just smoke the tires. They really stressed this point to the class. Sounds like maybe you are exiting launch control without realizing it?
Old Nov 30, 2014 | 08:45 AM
Thepiazza's Avatar
Thepiazza
Haven't tried launch control in my A6 yet but have been doing some reading on how. You still have to set you car up to perform launch control as if it were a manual. You didn't mention this in your post so I was just curious if you did so?
Old Nov 30, 2014 | 09:23 AM
Larry/car's Avatar
Larry/car
From what I have read here, seems launch control really abuses the car especially if you mess up. Not for me, I will accelerate manually without the aid of computer assist (I never get close to the rev limiter).
Old Nov 30, 2014 | 09:57 AM
Len44's Avatar
Len44
"...let the rpm stabilize..."
Just curious -- let the rpm stabilize at around what rpm?
Old Nov 30, 2014 | 07:47 PM
Hdhuntr01's Avatar
Hdhuntr01
You read many things both good and bad in the forums. The fact is that the C7 was engineered to perform Launch Control. This is not something we are doing with cars that is NOT RECOMMENDED by GM. This is something not only recommended by GM but also GM advises that the car was built to be able to do this without damaging any component. I suspect many hours of research and development went into Launch Control. I for one did not buy a $70,000 car for ALL SHOW / NO GO !!!
Old Nov 30, 2014 | 07:51 PM
Hdhuntr01's Avatar
Hdhuntr01
I will keep that in mind for the next time I have the opportunity to try out Launch Control but this past time I did in fact punch the brake and then punch the gas. The RPM's did rise and settle somewhere around 5000 (Not exactly sure where they stabilized, I didn't look at that specifically). Once the RPMs stabilized I quickly let off the brake and was smokin some rubber... Just no grip to it...
Old Nov 30, 2014 | 07:57 PM
mksz51's Avatar
mksz51
Do it daily for a month and then get back to us please.
Old Nov 30, 2014 | 08:00 PM
Hdhuntr01's Avatar
Hdhuntr01
If I had the time and place I would do just that. If something fails, well that's why I have a warranty...
However in a realistic world this is not something anyone would be doing on a daily basis, is it?
Old Nov 30, 2014 | 08:02 PM
mksz51's Avatar
mksz51
Depends on your age and maturity. The warranty isn't infinite - I'd worry about the abuse inflicted in the youth of the car showing at a later time.
Old Nov 30, 2014 | 08:10 PM
Larry/car's Avatar
Larry/car
I am not a waxer, and my car does go out in the rain. Compaired with some, I do very little maintenance. I like rural roads and triple digit speeds, however I will not take the chance of blowing my engine up attaining 60 mph in the blink of an eye. I have not even played with the 0 to sixty timer (afraid I'll get carried away and blow up my engine). Never said the desire wasn't there.
Old Nov 30, 2014 | 08:23 PM
Hdhuntr01's Avatar
Hdhuntr01
If your C7 is still under warranty, what are you worried about? I keep my car very clean and I drive it very hard. I am not some young kid who drives reckless but I do push the car hard at times and I feel that if the car was designed to do something, I expect it to do that. If it breaks in the process I expect GM to make it right. With that said, I do not drive it hard every time I get behind the wheel. Usually on the interstate I am in Eco and around town in Sport or Touring but when I have the occasional urge, I jump to Track and I expect it to perform like a >$70,000 machine should perform. I lived in Europe for many years and I have owned Porsche and Ferrari as well as many BMW's and Mercedes and I expect them all to live up to what the manufacturer says they will do. To this day, I have never blown an engine either...
Old Nov 30, 2014 | 08:24 PM
mdiiulio's Avatar
mdiiulio
IIRC A6 launch control stabilizes RPM at around 2k (I drive M7, stabilizes at 4k). It will be very obvious. Your foot will be on the floor (mash it... seriously, if you are timid it will disengage) and the RPM will be rock steady at 2k. If stable, release the brake as fast as you can and you will quickly hit 88mph and find yourself in 1985.
Old Nov 30, 2014 | 08:58 PM
Hdhuntr01's Avatar
Hdhuntr01
I will have to look at the Tach to see where the rpm's stabilize but I would swear it was higher than 2000. When I have the opportunity to test it out again, I will look to see where the rpm's stabilize.
Old Dec 2, 2014 | 12:21 AM
VegasAlleycat
I believe for the manual it is about 4000 rpm. They also demonstrated an automatic launch control which I believe stabilized at only around 1400 rpm. They said the auto is faster than the manual at launch control. Just a lot less dramatic at the lower initial rpm.
Of note, they stressed that GM does cover launch control issues under warranty for unlimited attempts. For comparison, they said the GT-R only allows 10 launches and then you void your warranty--yikes!
Old Dec 2, 2014 | 08:46 AM
Nosferatu's Avatar
Nosferatu
St. Jude Donor '14
hmm I'll have to try this on the C7. I tried it a while back on my C6 and from what I'm reading it may have exited launch control because I got a tire fest of smoke.
It's against my instinct to just pop the clutch while having pedal to the floor. I had it stabilize at 4000rpms but I felt wrong just popping the clutch. Now at over 600rwhp there's no way in hell I'm doing that on my C6 or bye bye drivetrain. I'll have to play with it on the C7.
Old Dec 2, 2014 | 09:13 AM
bigpete105's Avatar
bigpete105
Check out this video of Ron Fellows instructors explaining and demonstrating launch Control.
To Launch Control
Old Dec 2, 2014 | 09:42 AM
Woodson's Avatar
Woodson
You won't blow your engine. There is a rev limiter.
Old Dec 2, 2014 | 09:54 AM
JohnAE455's Avatar
JohnAE455
Didn't even know they had put launch control in the auto in the C7. I don't think that was available with the C6. I always thought the traction control would limit wheel spin in an auto and that the stall speed in the tranny would limit the rpm to about 2,000 rpm, at least it did on my previous auto's. At least the Corvette Black Book only mentions this feature available with the stick in the C6. Learned something new.
I think this car even rev matches with the auto on down shifts, at least in the Sport mode I leave it in. The first time I went from second to first at about 20 mph I was surprised that the engine revved before the shift. Great sound.
Old Dec 21, 2014 | 05:59 AM
SgtMajUSMC(Ret)'s Avatar
SgtMajUSMC(Ret)
Veteran: Marine Corps
A8 here and launch control works like a charm. RPM doesn't go higher than 3000 then stabilizes almost immediately at right around 1200. Simple process just as described in the owners manual. Let off the brake and it's gone as long as the wheel is straight and the go pedal is floored. Wheel spin is almost non existent.
Recently hit the 500 mile mark and have been experimenting. Aside from launch control, there is a very clear difference in driving modes. In Tour mode, spirited driving, there isn't a huge difference from normal driving. In Sport mode it clearly holds lower gears longer and stays in those lower gears longer during spirited driving. Emphasis on the spirited driving part here. Normal go pedal input equals normal shifts. Get on it at all and there is a very noticeable, almost violent, difference. Recommend experiencing that difference before mashing the go pedal in a populated area. Especially since the shifts in normal driving, regardless of mode, are so smooth/seamless. I didn't and had to change my shorts the first time I had it in Sport mode and tried to go around a stopped car in traffic. This isn't my first Vette either.....
