Oil PSI
Old Dec 5, 2014 | 05:37 PM
1SG_Ret's Avatar
1SG_Ret
Default Oil PSI
Curious what you guys are showing for oil pressure at idle and then at cruising.
My buddy is worried that his is too low at 30-32 PSI at Idle and 36-38 at cruising speed.
That's about what mine shows so I assume that's the normal. He was thinking around 50 PSI when cruising.
Never gave it a second thought. So I'm asking to put his mind at ease.
Old Dec 5, 2014 | 05:43 PM
Larry/car's Avatar
Larry/car
About right. If the oil pressure warning light doesn't come on, don't worry about it.
Old Dec 5, 2014 | 05:44 PM
Caholo1's Avatar
Caholo1
Mine is the same also.
Caholo1
Old Dec 5, 2014 | 05:53 PM
W88fixer's Avatar
W88fixer
I get 30-31 at hot idle and 35 when hot and cruising. Has gotten significantly smoother and seemingly quicker now at 2400 miles than when off the showroom floor. Don
Old Dec 5, 2014 | 09:15 PM
Bill B 1's Avatar
Bill B 1
that's about where mine is also. Z51
Old Dec 6, 2014 | 06:45 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
That is about where mine is. GM states the LT1 has an energy saving feature that varies oil pressure at lower rpm. It is more than the standard spring limiting max pressure. In addition it measures pressure where it is the lowest. Quoting GM:
"The crank-driven, variable-displacement oil pump can vary the oil pressure depending on demand. Oil pressure is measured at the last bearing surface in the oiling circuit, where pressure is typically lowest, to ensure that oil pressure is sufficient, even at the last bearing in the line
Old Dec 6, 2014 | 08:23 AM
1SG_Ret's Avatar
1SG_Ret
That is very enlightening and makes perfect sense explaining fluctuation and the lower readings..
Old Dec 6, 2014 | 02:04 PM
JerryU's Avatar
JerryU
I'll have to look when near red line. Usually things happening so quick and eye on the HUD TAC to read oil pressure!
Old Dec 6, 2014 | 02:11 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
Interesting. Not sure how much energy that saves tho. In any case, oil flow is far more important than pressure anyway; unfortunately there's no easy way to monitor that so pressure is what's measured and displayed.
Old Dec 6, 2014 | 09:19 PM
Ronbear's Avatar
Ronbear
Same here. I like to see 35 all the time but that is not what's happening.
Old Dec 6, 2014 | 10:02 PM
W88fixer's Avatar
W88fixer
Oil pressure is measured at the last bearing surface in the oiling circuit, where pressure is typically lowest, to ensure that oil pressure is sufficient, even at the last bearing in the line[/I][/B]."
Thanks for posting that, it’s very interesting.
In the “old” days, the standard used to be 10psi/1000 rpm so the 35 psi I get at 1500rpm when hot is fine, particularly if measured at the last bearing.
Add to that, if it is a “happy” engine and by that I mean where the mating surfaces are consistent, hopefully these engines should last a very long time, particularly when using synthetics. Don
Old Dec 9, 2014 | 04:12 PM
checkur6's Avatar
checkur6
Exactly the same as my Z51!
Old Dec 9, 2014 | 04:24 PM
Kracka's Avatar
Kracka
These days MPG is measured down to the decimals so every little bit helps. My 2nd car has a similar, variable displacement, feature for the A/C compressor so it drags as little on the engine as possible.
Old Dec 9, 2014 | 04:50 PM
BadUmp's Avatar
BadUmp
If you really want to get your head to spin like Regan Theresa MacNeil's in the Exorcist, go talk to a guy who builds top fuel eliminator drag motors about oil pressure vs flow and they'll give you a lecture that will make you wish you'd gone hunting or fishing instead... it seems to be a science in and of it self dependent on what the motor use will be. Or at least according to the last guy I asked, and got lost in the thought in about 3 minutes!
To Oil PSI
