Clearance for low profile jack?
this isn't necessarily tied to the hockey pucks but I do have a story about whenever I jack my car up and before I could secure it. Jack started rolling and my car actually rolled down a slope about 15 feet and the Jack never lost out from underneath it scared me half to death but the car never came off the jack. Ps I forgot to put parking brake on.....
E-Ray, 3LZ, ZER, LIFT
Received 9,647 Likes
As you read in my post, they had apparently cracked one C7 rocker panel! Since they had just recently had a technician certified for the C7 may have been a normal mechanic! I brought 4 jack pads with my C6 and put them on a the passenger seat there as well. These folks are in business to make a commission on service work not Vette hobbiest! It does take more time to put in the jack pads and line up the pads on a center post or side post lift.
Harbor Freight. $59.99.
Jerryu, you couldn't be more right regarding it all comes down to the money.....
My dealer service person (I actually know his name and have his cell #)!!!! called me up to ask me a question because he didn't have an answer to another C7 that was in his service shop. I'm thinking "really??? you're calling customers to get advice??" of course I had already read about the situation as it happened with my car. and do you know where I got my answer, and the answer that I gave to him??? Right here Baby!!!!!
There's nothing you guys don't know or are willing to find out.
this forum rules.
this forum rules.
this forum rules.
this forum rules.
Received 3,813 Likes
St. Jude Donor '03-'04
Can someone please confirm that this will work on my 2019 Stingray?
https://www.amazon.ca/VViViD-Heavy-D...032411&sr=8-39
That jack you show fits well under my lowered C5 and worked with my C7 barely, and then when I added the side skirts it did not because of the reach
fits under my stage 3 splitter
the extra reach clears my side skirts when jacking
Received 1,504 Likes
I know this was formerly a 6 year old thread. I can offer some insight... I have a very similar jack and it will fit under the car...however as the arm raises it will hit my side skirts.. so I bought a better jack ( low profile " long reach " ) and now use double height pucks, with this new jack... and have no issues with a lowered car.
Thanks for the detailed information, this helps!
Bill aka ET
Mad*Max (04-04-2020)
That short "jack arm" is about what I have in one of my 4 jacks. I only use it if just jacking a tire ~1 inch off the ground. For higher lifts, like when changing oil, I use two of my longer "Arm" jacks.
Note: I bought a long arm jack but weights 95 lbs and was NOT moving in on my tiled floor and would not on my rough surface concrete driveway. Concerned so welded on a larger lip to the flat saddle. It is about 3 1/2 inches high to the top of the welded addition and fits with a 1 inch high jack pad.
#33
Yep 3.4 inch min lift will work with a 1 inch high jack pad. However that 14 inch max is somewhat of a concern. You'll have to be sure the jack is perpendicular to the car and moves into the car almost 3 inches at max lift. If it didn't move it the jack saddle would slip off the jack pad! Also ne careful when you start that the rear caster wheels are set to move in. Just check after each pump.
JerryU (04-05-2020)
