Idling question
Old Dec 13, 2014 | 07:02 AM
TBRDS's Avatar
TBRDS
Default Idling question
I have a strange garage situation, where I park three cars one behind the other. The C7 is in the middle, with the DD behind it, by the garage door. When I want to drive the C7, I move the DD out, then move the the C7 out, and then put the DD back in the garage. Moving the C7 takes about one minute, and the question is, is it better to leave the C7 running for several minutes, while I move the DD back (and maybe wait for my wife to come out) or to shut down the C7 after bringing it out of the garage, and then restart it in a few minutes? The other option is to move the DD, and wait in the C7 for the wife, then start and move the C7, and leave it running (or not) while I put the DD back in the garage. Am I over-thinking this? (I can't leave the DD on the street as the community doesn't allow street parking.)
Old Dec 13, 2014 | 07:13 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Overthinking is an understatement.
Old Dec 13, 2014 | 09:08 AM
VINDIC8R's Avatar
VINDIC8R
Banned Scam/Spammer
You are probably overthinking this but let me ask, how safe is your community? Is there any history of car thefts? I live in a northern clime where some people will start their car and leave idling until the car warms while they wait inside. Every year we hear about some poor sap who lost his vehicle to someone lying in wait.
If not, let it idle and get hot. Perhaps get some of the moisture out of the pipes.
Old Dec 13, 2014 | 09:12 AM
1SG_Ret's Avatar
1SG_Ret
My thoughts exactly!
Old Dec 13, 2014 | 09:22 AM
Cruiter's Avatar
Cruiter
On order: Torch Red Z51
I'm going to inject a different thought here. I've always been trained that the most wear during engine run time is the 1st moments after it's started and while warming up, getting the oil flowing freely and the various parts that are rubbing together up to normal operating temps. If there's any truth in that then maybe you should evaluate your parking situation. Just my 6 bits .
Old Dec 13, 2014 | 09:25 AM
WelderGuy's Avatar
WelderGuy
You should check your local laws. In some places it's a misdemeanor to leave a vehicle running when you're not in it, even if you're only stepping away for a moment.
Ohio is one such place. http://www.clevescene.com/scene-and-...llegal-in-ohio
"In other words, anyone who leaves a running vehicle unattended, even if he or she is just stepping away while it warms up, can be charged with a misdemeanor and a $150 fine for omitting to stop the engine, lock the ignition, and remove the keys (emergency vehicles exempt).
"It also states the parking brake must be set (does anyone really do this?) and the wheels must be turned to the curb if the vehicle is left on a grade.
"Since the law does not specifically exclude private property from this statute, you can be cited for leaving the car running in your very own driveway."
Old Dec 13, 2014 | 09:31 AM
W88fixer's Avatar
W88fixer
When we lived in Albuquerque, NM, I saw that stunt and am amazed people do that. Cold, deal with it, start your car and drive off. Letting it idle while you’re inside drinking coffee whatever is simply inviting theft and they deserve to get it stolen.
Stunningly, when I asked USAA if they’d cover a theft under those conditions, they said yes (that was years ago, perhaps they have changed their viewpoint). In my opinion, they should refuse the claim, there’s no excuse for it and furthermore, it’s bad for the engine to idle like that, drive moderately after starting and then go about your business and the engine will be better served.
And great mileage idling, aka 0.
As to the OPs question, limiting cold idle time is a good idea but one can overdo it. Don
Old Dec 13, 2014 | 09:34 AM
W88fixer's Avatar
W88fixer
Three cheers for Ohio. In addition to the fact that leaving an unattended car idling is not intelligent, it might temp someone who otherwise might not steal a car to do so. More unnecessary legal issues. Don
Old Dec 13, 2014 | 10:00 AM
Wm Rose's Avatar
Wm Rose
We warm cars up all the time around here. Don't all new Vettes have remote start? Thats the reason for it. It can't be stolen, if the doors are locked and none of the electronics work without the key fob. The law in Ohio is ridiculous. Government intrusion at it's finest.
Old Dec 13, 2014 | 10:02 AM
Glen e's Avatar
Glen e
only automatics have remote start.
Old Dec 13, 2014 | 10:17 AM
MADMANC7's Avatar
MADMANC7
First, I wish I had three cars or a garage that would hold them.
Personally I would start BOTH cars first and then move as necessary.
As for the theft question, can't you just lock the doors?
Old Dec 13, 2014 | 10:20 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Interesting question! I’m my opinion, if you’re not going to drive the C7 for about 10+ miles to get the engine oil hot, then run it as little as possible! I have commented on threads where folks are wondering why the GM oil monitor is showing the need to change oil with very little mileage! The answer is they drive it mostly on very short trips! Worst thing you can do and the GM oil change algorithm takes that into account. Starting causes blow-by to get into the crack case. Idling for a short time time probably just makes it worse. If you could idle until the oil reaches 170 F, perhaps that is better.
My practice is to drive the Vette about 10 miles at least when I start it up, but from time to time I also have to take it out of the garage and put in back. I shut it down in-between.
I remind my wife that her dry sump SUV is also a problem when she uses it to visit a neighbor a very short distance away. We live 16 miles from town, so in general not a problem for either car.
I use my street rod mostly for local shows. It doesn’t run for months. I never pull it out of the garage (to get to a ladder etc.) unless I drive it 10 to 15 miles!
Just my thoughts.
Old Dec 13, 2014 | 10:28 AM
hawkgfr's Avatar
hawkgfr
I'm pretty sure that doesn't apply to home or private property...
To the OP if you crank it then run it to temperature unless you're going to drive within a few minutes anyway...imo
Old Dec 13, 2014 | 10:31 AM
hawkgfr's Avatar
hawkgfr
Really?....vehicles run all the time now unattended. More now than ever. Its called remote start. Oh and truckers never stop theirs and haven't for decades.
Old Dec 13, 2014 | 11:59 AM
TBRDS's Avatar
TBRDS
Thanks for the thoughts and advice!
Old Dec 13, 2014 | 05:03 PM
W88fixer's Avatar
W88fixer
The issue isn’t just about C7s, all sorts of cars are run unattended in the winter, use a tool and the thief is inside in a heartbeat. Don
To Idling question
