Glen e, I know you probably know the answers to my questions. 1- Can I remove the silver trim plate surrounding the gear shift without removing the center console. I know I need to remove shift handle and boot. 2- Can I remove the trim pieces that house the window switches without removing door panel. I'd like to paint/wrap these items. Any advice is appreciated. Thanks for your help. Allen
all the stuff on the driver door can come off wihtout removing door panel
pass door- must remove panel as hand hold goes thru the switch bezel
alum on shifter console is pressed on, never pried on it to find out if it would pop........
