Remove/Replace right dash trim pannel
Old Dec 17, 2014 | 03:42 PM
pkadams's Avatar
pkadams
Default Remove/Replace right dash trim pannel
Does anyone have a set of instructions on how to remove and replace the right dash trim panel (the one that has the climate control vents and controls attached) I am looking for a set of instructions like the ones that are in the "Master List of how to" above as in https://www.corvetteforum.com/forums...h-tweeter.html
but I am looking for instructions for this panel as indicated by the arrow in the picture below:
I have a new pannel and it looks like it goes in with clips, as most panels do; but three of the clips have a threaded area that looks like something is screwed on those clips. Before it gets pulled off I would like to understand the purpose of those three screw holes
Old Dec 18, 2014 | 08:13 AM
Buzzardz_vette's Avatar
Buzzardz_vette
Don't know about the panel, but where did you get the drawing?
Old Dec 18, 2014 | 01:21 PM
pkadams's Avatar
pkadams
Click on this link and it will take you to the drawing.
Old Dec 18, 2014 | 03:34 PM
Zymurgy's Avatar
Zymurgy
Moderator
Isn't there an airbag back there? Could those be to mount the airbag?
Old Jan 5, 2015 | 11:59 PM
CopRodder's Avatar
CopRodder
Can you post procedure on installing carbon dash if possible
thanks
Old Jan 6, 2015 | 12:04 AM
SharkGrayStingray's Avatar
SharkGrayStingray
brother, that should be where the air bag comes out of. make sure the new piece is approved to go in front of air bag and will not harm someone if it goes off. i wouldn't mess with it...
Old Jan 6, 2015 | 12:47 AM
Da Hawk's Avatar
Da Hawk
thanks
Here you go. The first link contains a step-by-step video tutorial.
https://www.corvetteforum.com/forums...nd-videos.html
https://www.corvetteforum.com/forums...p-by-step.html
Old Jan 11, 2015 | 11:44 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
pkadams: This is a complicated procedure that I've helped a handful of people with.
If you still need help with this, let me know. It's silly the amount of removal takes place for this one piece replacement.
Old Jan 13, 2015 | 12:31 AM
Zajac's Avatar
Zajac
Default passenger trim panel
Here is a pic of the backside of the passenger trim panel. I have read that it is the trim screw adjacent to the center console that require access through the center console.
Note, I have only read this but I have not actually read any writeup on how much work or how to get access to the difficult console side screw.
I am thinking about removing/replacing the passenger trim panel above the glove box also but waiting/searching for some info and instructions.
Old Jan 13, 2015 | 02:52 AM
Theta's Avatar
Theta
I'll just make a How-To of it since I've sent it out about a half-dozen times to folks.
Look for it tomorrow. It begins with removing the center console, just so you're prepared.
Old Jan 19, 2015 | 06:54 PM
Zajac's Avatar
Zajac
The waiting for instructions is suspenseful. The wait probably is an indication of the difficulty of replacing this passenger trim panel.
Old Jan 19, 2015 | 07:32 PM
Theta's Avatar
Theta
No, my fault - ended up in the hospital again because my luck is always the best. If it makes you feel any better, I actually thought about this the next day and said "sh**, I needed to do that" but my files are on this terminal.
Will do it right now, for real this time!
Old Jan 19, 2015 | 07:37 PM
Theta's Avatar
Theta
Thanks for your patience - here's the start of the battle.
Starts with removing the center tray (so the same first steps to replace the shifter):
Attachment 48369470
Attachment 48369471
Attachment 48369472
Attachment 48369473
Attachment 48369474
See my walk-through here for better (real) pics.
Here: http://forums.corvetteforum.com/c7-t...k-shifter.html
Next part coming up...
Old Jan 19, 2015 | 07:43 PM
Theta's Avatar
Theta
On to the next parts - working up to glovebox removal:
Old Jan 19, 2015 | 07:44 PM
Theta's Avatar
Theta
They only list the driver's pic - just do this on the passenger side:
Theta's Avatar
Theta
Glove Box Removal:
Just in case - how to open the glovebox without power:
Old Jan 19, 2015 | 07:45 PM
Theta's Avatar
Theta
And finally, the holy grail:
To Remove/Replace right dash trim pannel
Old Jan 19, 2015 | 07:46 PM
Theta's Avatar
Theta
Lots of fun for one panel, eh?
I'll make a formal DIY out of this now, but I wanted to put all the info here ASAP.
Best of luck!
Old Jan 19, 2015 | 08:07 PM
pkadams's Avatar
pkadams
Best of luck!
Got it!!!! Thanks looks like a nice rainy day project.
Old Jan 19, 2015 | 08:12 PM
Theta's Avatar
Theta
I've been told by the several people that I've helped with it that it takes around 3 to 5 hours total depending on how familiar you are with the dis-assembly, etc.
Indeed perfect for a leisurely rainy day.
