Music solution
Old Dec 22, 2014 | 04:13 PM
grandpawmoses's Avatar
grandpawmoses
Originally Posted by VINDIC8R
Thank you. Question, when you say you get all the benefits as the iPod, do you mean the album data, etc registers on the screen?
It displays the artist, song title, and (if known) the album. There is an SD card icon on the left and if you touch it a menu appears across the bottom to select playlists, artists, song titles, albums, etc. There's another larger SD card icon on the right side & if you touch it, it displays (in a vertical format) all the titles in the selected playlist, artist, album, etc. You can pick titles directly from this list by touching it. Hope this helps.
Old Dec 22, 2014 | 04:50 PM
aj98's Avatar
aj98
Originally Posted by Woodson
Yeah, I find the indexing time to be a little frustrating as well.
Why is it in your cupholder and not behind the screen or in the armrest?
The classic uses a physical hard drive, not flash/solid state chips, so behind the screen may get bounced around harder than I would like - in the cupholder pretty much eliminates lateral shock.
Not under the armrest because...
(laundry list)
too much stuff already in there
potential heat issues (ala C5)
habit from my other car where I have to manually control some aspects the ipod
I don't usually leave it in the car, so it gets disconnected and goes with me
Old Dec 22, 2014 | 04:52 PM
oyealiz's Avatar
oyealiz
2022 C8 of the Year Finalist - Unmodified
CI 3-4-5-6-7-8-9-10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'16
Originally Posted by Apocolips
Yes, I can browse by album, songs, playlist, or artist. Works great!!!
I should have asked someone to download all the tunes and set this all up for me for Christmas!
Old Dec 22, 2014 | 05:36 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Had an iPod Nano in my C6 (with a PAC iPod adapter) and it worked fine.
However, I have never used the Ipod in my C7 as I don't need it.
Instead I use an SD card and have all the functionality of the iPod without tying it up and taking up a USB port
Old Dec 22, 2014 | 06:07 PM
Swt_86's Avatar
Swt_86
Default USB Device Music
I have a couple other vehicles with the USB music feature and have been using it extensively for the last few years. Once you have your music in an mp3 format, there are a couple of programs/tools that really help.
One is Mp3tag. This is a free utility that you can download from the internet. With it, you can add album art, change the information displayed on your system etc.
Another is MP3Gain. Again, a free utility you can download. It allows you to modify the volume of your mp3 tunes. The native volume levels can vary greatly, making you turn the volume up and down which can get very annoying.
By the way, probably the quickest and easiest way to create a play list is to open a command window, change to the drive you have your USB music on and type "dir /b>playlist.m3u" (without the quotes) where "playlist" is the name of the file created.
If you have any questions, please feel free to pm me. I would be glad to help.
Old Dec 22, 2014 | 06:23 PM
BIG Dave's Avatar
BIG Dave
Originally Posted by Swt_86
I have a couple other vehicles with the USB music feature and have been using it extensively for the last few years. Once you have your music in an mp3 format, there are a couple of programs/tools that really help...
MP3 is the LAST format someone should choose. Sounds like nails on a chalkboard!
Old Dec 22, 2014 | 06:26 PM
KenHorse's Avatar
KenHorse
I doubt most could hear the degradation of an MP3.....
Old Dec 22, 2014 | 06:35 PM
grandpawmoses
I recently discovered MP3Gain, it allowed me to "batch" set all of the volume levels of my music to the same level I chose. That's been a major pet peeve of mine for a long time.
Old Dec 22, 2014 | 09:44 PM
fdxpilot's Avatar
fdxpilot
Originally Posted by jma242
Has anyone attempted hooking up a hard drive filled with some music to the USB? I know that works with some aftermarket receivers. Just curious as I don't have a C7 yet.
The owner's manual says USB hard drives are not supported, but some forum members have reported success.
Old Dec 22, 2014 | 09:52 PM
fdxpilot's Avatar
fdxpilot
If all the data is encoded in the .mp3 files, it will show up in the infotainment screens. What program you used to create the .mp3 file will determine what info is encoded with the music. I use an encoding program called Exact Audio Copy, which has an album lookup feature, as well as varying bitrate encoding. I usually encode at 320kbps, and in an auto audio environment , it is indistinguishable from a CD to my ears. I have over 4600 songs on the 32GB SD card in my wife's C7, and it is less than 3/4 full.
Old Dec 22, 2014 | 10:05 PM
doug doo wop's Avatar
doug doo wop
I have two Ipod classics, one for the vette and the other for the other cars. I plug it in behind the screen but it went dead on me after leaving it in the car for a few days;I don't believe it charges in the usb port. Also, I do have a problem, in that when I turn the car off and come back to drive off, the music doesn't continue where I left off. Then I have to unplug the Ipod and re plug it to get it started again. I don't know why it does that. I have 160GB ipods.
Old Dec 23, 2014 | 02:18 AM
hawkgfr's Avatar
hawkgfr
(laundry list)
I have a brand new classic(I had it for a year unopened and decided to use it for the Vette.) It works great but leaving it in the car every few days I have to unplug it and plug it back in. For some reason it randomly looses contact with head unit. By taking yours with you must be missing that.
I wish I had a fix for the classic and that small bug. I'll probably put my touch in the car and see how it does...It just has a lot less space on it. I don't keep music on my phone.
I'm afraid the thumb drive or sd card won't sound as good...
Old Dec 23, 2014 | 02:20 AM
  #33
hawkgfr's Avatar
hawkgfr
Mine charges in both places....seems to work better behind the head unit but still looses touch and I have to unplug and start over every so often, but not every time. In the console it is almost every day.
There has to be a fix for it lol...
Old Dec 23, 2014 | 09:01 AM
  #34
Apocolips's Avatar
Apocolips
I have tried several times to down load Mp3Gain with no luck. Every site that I try wants to add or change things on my computer. I have even tried the custom download but it still won't load properly. Where did you down load it from?
Old Dec 23, 2014 | 10:03 AM
  #35
Woodson's Avatar
Woodson
I have the same problems with my classic.
The files are digital so the songs sound just as good on the sd card and the access is quicker. The problem for me is the capacity.
Old Dec 23, 2014 | 10:42 AM
  #36
Swt_86's Avatar
Swt_86
Default MP3Gain
Try it here:
http://mp3gain.sourceforge.net/download.php
That is the developers website.
Old Dec 23, 2014 | 11:15 AM
  #37
FiremanC7's Avatar
FiremanC7
Default iPhone Issue
I have a 64GB iPhone 5 and have no trouble getting it to sync with the car, but when I try to stream music from it I have to turn the volume way up just to here it. I've already put my music on a large thumb drive and that works fine, but I'm curious as to why im'm having this problem.
Anyone have an idea?
BobD
To Music solution
Old Dec 23, 2014 | 11:16 AM
  #38
grandpawmoses
I had a very old IPod Classic that had a battery issue with going dead overnight. The USB port only charges when the ignition is on. This resulted in various issues with connection like not continuing with the current song, or playlist, or even having to disconnect & reconnect for the IPod to be recognized. I bought a replacement battery off fleabay that solved the issues unless the car wasn't cranked for a few days. That 9 month old battery recently died & I opted to try the SD card. I can't think of any reason why the music quality of an .mp3 file from an SD card should be any different from an IPod.
Old Dec 23, 2014 | 11:25 AM
  #39
grandpawmoses
BobD
Try the mp3gain utility previously mentioned. It will set the volume level to your song library so every song is the same level and you can adjust that level to any level you want.
Old Dec 23, 2014 | 11:40 AM
  #40
beachcomber's Avatar
beachcomber
BobD
Not to say you haven't checked, but the volume on the iPhone 5 side button has to be turned up as well, otherwise you'll get little to no audio from the car. I just keep the iphone turned up to full volume and use the car audio to control the volume level.
