Storing my C7
Old Dec 31, 2014 | 10:49 AM
indies275's Avatar
indies275
2nd Gear
Default Storing my C7
I'm from Ohio but I have my C7 taken to Florida and I discontected the neg. battery terminal when I left for Ohio 2 months ago will everything fire up when I return next week? Indies 275
Old Dec 31, 2014 | 11:01 AM
RottenII's Avatar
RottenII
See no reason why it shouldn't.
Old Dec 31, 2014 | 11:23 AM
VETJAZZ's Avatar
VETJAZZ
That's what I'd do.
Old Dec 31, 2014 | 12:02 PM
CO Lightfoot's Avatar
CO Lightfoot
Should be fine -- unless the battery was already weak when you disconnected it.
Anyway, you'll probably have to re-initialize window indexing. Very easy. See pg 2-23 in the '14 Owner's Manual: http://www.chevrolet.com/content/dam...14corvette.pdf
And if you don't know how to manually open the trunk/hatch...
Old Dec 31, 2014 | 12:58 PM
Larry/car's Avatar
Larry/car
When you connect the battery wait a few minutes for the systems to power up or when you hit the start button the engine will not turn over (acts like the battery is dead), a few minutes later the engine cranks and starts right up.
Old Dec 31, 2014 | 04:54 PM
rotherd31's Avatar
rotherd31
No electric available down in FL? If not, I would probably do what you did. If you have power, I'd just spend $35.00 for a battery tender. Plug it in the socket in the right rear, under the hatch and have no worries.
To Storing my C7
