PDR issue
Old Dec 31, 2014 | 04:55 PM
cheapthrills's Avatar
cheapthrills
Default PDR issue
I bought a scandisk 32gb SDHC card. seems to be formatted as fat32. I put it in the SD slot but PDR state no SD card found. Any thoughts or help appreciated.
Old Dec 31, 2014 | 05:01 PM
FiremanC7's Avatar
FiremanC7
Which slot did you use? The PDR uses the slot in the glove compartment. Also, check the format. The one I bought was a similar format, but not exactly Fat32. You may need to reformat.
BobD
Old Dec 31, 2014 | 05:18 PM
grandpawmoses's Avatar
grandpawmoses
You're probably putting the SD card in the Infotainment slot in the center console.
Old Dec 31, 2014 | 05:22 PM
cheapthrills
BobD
Duh. You are correct. I didn't even know one was in there I used the center console. Thanks for the help
Old Dec 31, 2014 | 05:44 PM
cheapthrills
Yep and the glove box worked, thanks.
To PDR issue
