I was going to order the AL Priority Laser Jammer but was looking the car over to see where to mount the quad setup, two front and two rear. I've searched the site but can't seem to find where anyone mounted these with pics on a C7.
Has anyone done this? I'm in the Orlando, FL area, anyone know of a good installer?
I'm not familiar with the AL Priority system, but I used to have the Laser Interceptor quad system on my C6 Z06. The LI was very effective and saved me many times. The most popular and proven laser jammer brands are Laser Interceptor and Blinder. The Blinder HP-905 has really small sensors, which make stealth installation easy. Sorry, I haven't seen an install on the C7 yet. Good luck!
Semper Fi..
Mounting the heads are going to be similar among the different manufacturers there all pretty much the same size so don't let that be the only deciding factor
I have the Laser Interceptor and running the wires through the fire wall into the cabin was a real pita, the AL Priority has a BT module as a option so that cleans things up and easier install.
Check out one the detector/laser forums for more detailed info.
Rob
