Anyone mix 100 octane gas with 91/93 octane?
I recently found a 76 gas station in SoCal with 100 octane gas, at a ridiculous $9.39 a gallon. For comparison, 91 was $3.09 at the same station.
Anyhow I saw another thread on the forum about gas grades and thought I'd ask if anyone has mixed 100 octane with 91? And if it made any noticeable difference?
I'm going to try mixing a 50/50 blend of 100 octane and 91 just for the heck of it. Not going to do it regularly, just to try it out.
There used to be a 76 in Thousand Oaks that had 100 octane at the pump, but they no longer have it.
Where was the 76 that you found ?
I have done the mix in my 93 LT1, and my 03 LS1. Really didn't notice any difference, other than I knew I had 100 octane instead of 91.
It's a 76 station in south Pasadena. The address is 155 East Glenarm, Pasadena CA.
Unless you're tuned for it you really won't see any difference. You could use one of the online octane mix calculators to get 93/94 octane instead of our 91 and see if you feel anything, but it's unlikely as it's just a few HP.
In my last Turbo car the tune I had was selectable between 91, 93 and 100 octane tunes on the fly (just restart the car) and I used to use the calculator to run 94 and sometimes straight 100 octane. With the right tune, there is power that can be had, but the factory tune is set to run conservative.
My guess is you'll do it once and then not want to do the extra cost of the fill-ups with the results in a stock car.
Received 3,290 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
I would have loved to put in 100 octane in the 68 big block I once had. It would have made a diffeence as the engine was made for it-well sort of as those engines back then used leaded gas.
It's an absolute waste of money and in most instances it will actually reduce overall performance as the high octane fuel has the potential to cause the ECM to go into a protected mode. The ECM expects to see detonation, even with the recommended octane rating. If, over time it doesn't detect any it may assume the knock sensors are defective and go into the low octane map. I know this used to be the case a few years ago but I'm not fully up to speed on the algorithms in the newer ECMs.
Bottom line, don't waste your money.
AIR FORCE VETERAN
I worked in racing gasoline for over twenty years. There is no additional power with increased octane above the manufactures recommendations. You can increase power with high octane if your car has been tuned to take advantage of the increase. As an example higher compression. With computer controlled tune ups there is no change because the engine does not see changes that would demand high octane. When I started in gasoline NASCR used 110 octane. Now the octane ratings are less then 100. Octane itself does not increase the energy in gasoline.
My other car is a Focus ST which is a turbo and I run an E30 mixture to increase octane. The car has been tuned for it, switchable maps on the fly from a Cobb tuner. The E30 is awesome in a tuned turbo. As others have said it's a waste unless you run a tune to take advantage of it.
Way too many people think more octane = more power. The C7 Owner's Manual calls for 91 octane, which tells you that's what the ECM is programmed for. Using higher than that will not give you more performance or any other advantage for the added cost.
Received 2,379 Likes
For the vast majority of C7 owners, yes.
