Removing Carpet For Fatmat Install?
Old Jan 23, 2015 | 07:49 AM
stephen1254's Avatar
stephen1254
Default Removing Carpet For Fatmat Install?
The title says it all. I'd like to completely remove the carpet from behind the seats to the back of the car, in order to do the cleanest and most seamless install. Can anyone share how they have done this?
I saw a picture on this forum of someone who had done this, but there was no accompanying explanation as to how the carpet was removed.
Old Jan 23, 2015 | 08:47 AM
pkadams's Avatar
pkadams
Glen e did the Fatmat installation. On the C7 coupe the carpet is not attached at the bottom behind the seats and just lifts out of the way. Not sure if this is also true with the vert or what you have to do with the waterfall on the vert? In Glen e's picture he just lifts the carpet out of the way and places it in the cargo area until the install is completed.
Old Jan 23, 2015 | 08:54 AM
stephen1254
I had seen that install, but what I am looking to do is completely remove the carpet, as I am going to install the Fatmat under the carpet in the cargo area. I think what Glen e did was place the Fatmat on top of the carpet in the cargo area, and under a cargo mat. I don't have a cargo mat nor do I plan on putting one back there.
Old Jan 23, 2015 | 12:10 PM
Swt_86's Avatar
Swt_86
I pulled the cargo area carpet out to remove the battery for winter storage. You need to take the "D" rings off - there is a torx screw - I think it is a T25 - under each of the two plastic covers. Once off, the carpet lifts out. It is tucked under the side plastic trim pieces, so lift it from the center. Hope this helps.
Old Jan 23, 2015 | 12:15 PM
stephen1254
Thank you - that helps a lot. My project for tomorrow!
Old Jan 23, 2015 | 04:35 PM
C8Jake's Avatar
C8Jake
Old Jan 23, 2015 | 05:52 PM
stephen1254
Originally Posted by C7Jake
Those were the pictures I first referred to - there was just no accompanying description as to how you got the carpet out.
That certainly looks like a thorough installation!
Old Jan 23, 2015 | 09:39 PM
C8Jake's Avatar
C8Jake
Do it right...remove side & rear trim panels
Old Jan 23, 2015 | 10:08 PM
mdiiulio's Avatar
mdiiulio
Click Here
This is what you are looking for. Enjoy and good luck.
Old Jan 24, 2015 | 10:32 AM
pkadams's Avatar
pkadams
Has anyone done this project on a vert? If so any suggestions on how to get the waterfall off?
Old Jan 24, 2015 | 10:34 AM
HDBADDOG55's Avatar
HDBADDOG55
Please advise as to "how" you removed the side & trim panels. Thanks!
Old Jan 24, 2015 | 10:45 AM
HDBADDOG55's Avatar
HDBADDOG55
Originally Posted by mdiiulio
Click Here
Yes. Thanks. Great post
Old Jan 24, 2015 | 10:59 AM
Algiers's Avatar
Algiers
That looks great. Did you use the 25 sq ft pack for this?
Old Jan 24, 2015 | 04:06 PM
C8Jake's Avatar
C8Jake
exactly
Old Jan 24, 2015 | 10:11 PM
alienranch's Avatar
alienranch
There is a sticky post on this. Pretty easy to do - did it today for a hard wire radar detector install.
Old Jan 31, 2015 | 07:40 PM
Tony B's Avatar
Tony B
Default Great Job
Ready to do this....how much FATMAT is needed for behind seats and rear cargo area? Also did you use Rattle Trap?
Tony B
Old Feb 1, 2015 | 12:29 AM
C8Jake's Avatar
C8Jake
25'sq...RattleTrap
To Removing Carpet For Fatmat Install?
