What size socket for lug nuts
Old Feb 5, 2015 | 10:43 PM
beachcomber's Avatar
beachcomber
Default What size socket for lug nuts
Quick question, as I'm out of town and about to hit the local hardware store. What size socket is used on our C7's? I can't recall but believe it's 13/16. Can anyone confirm for me real quick what the correct size is?
TIA!
Old Feb 5, 2015 | 10:48 PM
millpond's Avatar
millpond
19mm
Old Feb 5, 2015 | 10:49 PM
beachcomber
Originally Posted by millpond
19mm
thanks for the quick response, just what I needed. Thx!
Old Feb 5, 2015 | 11:04 PM
3 Z06ZR1's Avatar
3 Z06ZR1
19mm
Or 3/4 both fit?
Old Feb 5, 2015 | 11:49 PM
W88fixer's Avatar
W88fixer
You really need a deep well socket. Don
Old Feb 6, 2015 | 08:22 AM
Glen e's Avatar
Glen e
Old Feb 6, 2015 | 09:29 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Officially 19mm but 3/4 will work.
0.7480 in. (pretty close to 3/4") = 19.0000mm
13/16" = 21 mm Too big, won't work.
Elmer
Old Feb 6, 2015 | 12:04 PM
MeanDean43's Avatar
MeanDean43
Well, that gives you a pretty good choice, the only thing that they left out was a sledge hammer!
Old Feb 6, 2015 | 12:10 PM
nmerhaut's Avatar
nmerhaut
I bought a deep set 19mm NON-Marring socket at Harbor Freight last year. Haven't used it but it was inexpensive. FYI.
Old Feb 6, 2015 | 12:13 PM
corvettecop's Avatar
corvettecop
Get a disposable rubber glove, cut off the fingers and use them to line the socket to prevent marring of the lug nut. I say "fingers" because they have to be changed out for each wheel. Works great!
Old Feb 6, 2015 | 12:24 PM
nmerhaut's Avatar
nmerhaut
Great idea.
Old Feb 6, 2015 | 12:37 PM
Glen e's Avatar
Glen e
I just painters tape the socket.
Old Mar 22, 2015 | 02:28 PM
930man's Avatar
930man
19mm will not fit on mine? Confused
Old Mar 22, 2015 | 02:38 PM
gpotski's Avatar
gpotski
I ordered a 19 mm 6 sided socket from amazon to use.
All the local stores only carry 19 mm in 12 point sockets.
Old Mar 22, 2015 | 02:58 PM
Sir Nuke's Avatar
Sir Nuke
as the others have said.....19mm or 13/16" work.....but in both cases, always get and use a 6 point socket.....and a deep well.
Old Mar 22, 2015 | 03:06 PM
C7 Laguna Blue's Avatar
C7 Laguna Blue
A 3/4" socket fits my 2015 just a wee bit better than a 19mm socket.
3/4" = 19.05mm. It's so close I don't think it matters.
Old Mar 22, 2015 | 03:26 PM
bluvette2000's Avatar
bluvette2000
Confused info here.
19 mm or 3/4 both work on the original lugs. 13/16 or 21 mm work on some replacement lugs such as the Gorilla lock key lug.
To What size socket for lug nuts
Old Mar 22, 2015 | 03:36 PM
eboggs_jkvl
Moderator emeritus
13/16 is NOT the size for the OEM lug nuts.
Officially 19mm, per the manual, but 3/4 will work.
Elmer
Old Mar 22, 2015 | 04:03 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Was using plastic sandwich bags but they wore after a couple of lugs. Bought this plastic insert 19 mm socket for the C6 black lugs, works perfect for the C7 powder coated black wheels. A little pricy.
Great tool. However Expensive.
Old Mar 22, 2015 | 06:50 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
If you are out of town now, why did you need to know now instead of waiting til you got home?
