TPMS Reset?
Old Feb 7, 2015 | 10:35 AM
A6T34ME's Avatar
A6T34ME
Default TPMS Reset?
What needs to be done when switching wheels with new tire pressure sensors?
Old Feb 7, 2015 | 10:37 AM
Glen e's Avatar
Glen e
they should automatically see the new sensors...about 20% of the time they don't, and then you need to do this - this is not in the manual...
1. start car - actual engine running - not the Acc mode
2. Select the tire pressure display in the DIC.
3. Press and hold the SEL button until the display changes and the horn beeps. It now says it's in learn mode.
4. Now drive just as it says in the manual - 10 min or so above 12 mph.
5. Suddenly, it will find all 4 sensors and show pressure
6. when you shut the car off , the "learn DIC" will show again and horn beeps.
Now you are done…
Old Feb 7, 2015 | 10:42 AM
A6T34ME's Avatar
A6T34ME
Now you are done…
Thank you. Sounds Easy!!
Old Feb 7, 2015 | 06:01 PM
vettekat2007's Avatar
vettekat2007
Glen or anyone else:
Does this method work on older style TPM sensors in use before the '14 and '15 models?
Old Feb 7, 2015 | 06:07 PM
PARANORMAL's Avatar
PARANORMAL
SUPPORT AUTISM
St. Jude Donor '10, '14
This method will not work with pre 14 Vettes. 14-15 With correct replacement sensors, the car will auto learn them.
Old Feb 7, 2015 | 06:14 PM
Glen e's Avatar
Glen e
With the correct sensor, 14-15 will still have a small amt that will not auto learn. The wheel vendors here have also experienced this. I have had 3 sets of the correct part #’s, 2 were fine, 1 needed the forced learn above.
Old Feb 7, 2015 | 06:33 PM
PARANORMAL's Avatar
PARANORMAL
SUPPORT AUTISM
With the correct sensor, 14-15 will still have a small amt that will not auto learn. The wheel vendors here have also experienced this. I have had 3 sets of the correct part #’s, 2 were fine, I needed the forced learn above.
Guess I have been lucky with my two sets. Good to Know the manual option.
To TPMS Reset?
