Need Help About Plastic Engine Cover....
Old Feb 8, 2015 | 11:29 AM
ArcticC7's Avatar
ArcticC7
Default Need Help About Plastic Engine Cover....
Trying to remove just the part that says Corvette on it. I tried yanking on it but it wouldn't budge. Dont want to get to agressive until I know for sure they should just pull off? Thanks.
Old Feb 8, 2015 | 12:00 PM
TEXHAWK0's Avatar
TEXHAWK0
Yes, they just pull off.
Try pulling the top edge off first...
https://www.corvetteforum.com/forums...r-removal.html
Old Feb 8, 2015 | 08:13 PM
nmvettec7's Avatar
nmvettec7
The fuel rails will simply pull off. They are only secured by a rubber grommet on the top portion. There are 2 grommets about 12 inches apart from each other and about 6 inches from the end on each side. Pull up from the top towards your upper body. There is a steel shaft that is inserted into the rubber grommet. The steel shaft slides into the gromment to hold the fuel rail in place.
Once you do one, the other is a breeze.
To Need Help About Plastic Engine Cover....
