FUEL: Premium versus Regular
What's the verdict about running premium versus regular fuel?
Does the engine really perform better?
Will it hurt the car if you don't run premium gas?
Higher octane fuel isn't about "better performance," it's about protection from knock that can damage an engine.
Verdict : Run the recommended grade of gas (91-93)
Yes, engine will perform better. It won't knock under hard acceleration and the computer won't have to adjust timing to allow for the lower octane.
It probably won't if you drive the car normally - meaning no hard acceleration at all. Just putt along and 87 will likely not cause any harm. Is it worth the risk on a $60K-$70K car? Warranty issues if something happens in the engine even if unrelated?
However for a max difference of $6 per tank full of 93 vs. 87, not sure it's worth the savings to not be able to drive the car with a clear conscience, be able to put your foot into if you choose and have some fun.
Octane rating, is anything more misunderstood?
Octane, amongst the gasoline molecules (heptane, octane, nenane, decane) has the desirable characteristic that it can be compressed quite a lot before it spontaneously combusts. It also burns slower. A 4 cycle gasoline car engine doesn’t count on spontaneous combustion. Instead it assumes that combustion will occur when the spark plug fires. If the gasoline combusts before the spark plug fires (beginning of power stroke), the engine will not make maximum power and can be damaged.
The compression ratio of the engine determines the amount of octane you need in gasoline. The higher the compression ratio, the higher the octane percentage. If you use low octane gas, can you live with the effects of pre-detonation?
But unless you are an independent testing lab trying to test the capabilities of the knock sensors and timing tables or the robustness of the piston faces when subjected to pre-ignition then putting regular grade in a C7 just for the hell of it comes under the heading labeled GOOFY...
Some people's kids.....
On a serious note, just buy the premium grade and enjoy everything the engine has to offer. Will you hurt anything with 87? Probably not...but the ECU will retard timing and reduce engine output.
What it means if you are 90 octane is that the fuel has the same antiknock performance as a blend of 90% 2,2,4 TMP (the compound rated 100) and 10% n-heptane (the compound rated zero). Gasoline as it comes out of the ground from Mother Nature has an octane of about 60. The refinery must change its chemical composition to introduce more chain branching, aromatic rings, and olefinic bonds, to get it up to the desired level. Premium is more expensive than regular because it must be blended from more severely processed components. Having said that, the marketers charge much more for premium than it really costs to make. The true cost differential to make 93 premium versus 87 regular is about 8 cents per gallon. So what a marketer does is raise the price of premium until its price scares people away. This benefits him on both sides, making more money on the premium, and also allowing him to sell the regular for less by subsidizing it with the profits from premium.
When I had a daughter living at home and driving the C5 and GTO I would use 87 octane.
It slowed the cars down with no side effects--no knocks--pings--or other adverse effects--and the C5 has been in the house for 17 years.
