C7 Z51 package
Old Feb 11, 2015 | 12:13 PM
11B250's Avatar
11B250
Originally Posted by KenHorse
Uhhhhh....I thought there were specific allocations for Z51 and other specific allocations for non-Z51. And I also thought that once the order went to 2000, there were no changes allowed?
it's true. you can't add Z51 once you hit 2000.
Old Feb 11, 2015 | 02:04 PM
HighTeq's Avatar
HighTeq
Z51
Old Feb 11, 2015 | 02:23 PM
up4sunshine's Avatar
up4sunshine
Cruising
Originally Posted by HighTeq
Z51
yep, I included the Z51 package with mag ride control. Since it comes with the performance exhaust, the difference wasn't that much!
Old Feb 11, 2015 | 02:24 PM
up4sunshine
Cruising
I called the dealer and they said that was true for the Z06 but not the Z51. I added it to my options.
Old Feb 11, 2015 | 02:27 PM
fdxpilot's Avatar
fdxpilot
Actually, other than being only available with the Z51 package, the MRC Package is of more value on the street than the track. Most tracks a relatively smooth, and don't get nearly the benefit from the MRC shocks that a driver on the average poorly maintained public street will get. If I could have gotten the MRC suspension on the base car, my wife's C7 vert would have it. My '13 C6 has it, and my incoming Z06 has it.
Good luck with that. Experience by Forum members over the last year and a half says, unless your dealer has an allocation allowing the Z51 package when GM accepts the order, you're not going to be able to add it after status 2000, "Order accepted by GM." If your still at status 1100, "Order entered by dealer," then you can add it. Your dealer will still need an allocation allowing the Z51 option, only one out of 2 orders, to get it accepted.
Old Feb 11, 2015 | 02:33 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Your dealer is lying to you - there is no such thing Z06/Z51
Old Feb 11, 2015 | 02:37 PM
up4sunshine
Cruising
I know there is no Z06/Z51. What I meant was, the limit is on ordering the Z06. They are limiting how many Z06s are ordered. They are not limiting how many of the regular corvettes can have the Z51 packages included. If you have a specific link that you could forward me that sys that, I would appreciate it.
Old Feb 11, 2015 | 02:43 PM
fdxpilot's Avatar
fdxpilot
Link to the constraint report for 29 Jan. there were no Vette allocations on 5 Feb. 50% limit on Z51. Of course this assumes you trust our forum at least as much as your dealer.
https://www.corvetteforum.com/forums...march-2-a.html
Old Feb 11, 2015 | 02:44 PM
KenHorse's Avatar
KenHorse
Originally Posted by fdxpilot
Link to the constraint report for 29 Jan. there were no Vette allocations on 5 Feb. Of course this assumes you trust our forum at least as much as your dealer.
Yup. His dealer is ly....errrr.....misinformed..
50% Z51 constraints......
Old Feb 11, 2015 | 02:55 PM
up4sunshine
Cruising
Thanks!
Old Feb 11, 2015 | 02:56 PM
A6T34ME's Avatar
A6T34ME
Default Pacific Design Package? Unique Aero Package?
Originally Posted by ILuvUMan
Sway bar? You going to the race track?
If you are going to race it, the Z51 is worth the money.
I'd venture to guess, most Covettes NEVER see a race track.
Here's what you get with the Z51 Package;
Pacific Design Package for Stingray Coupe
Atlantic Design Package for Stingray Convertible
Larger 19-inch front and 20-inch rear wheels
Dry sump oil system
Electronic Limited Slip Differential
Larger front brakes (13.6 inch vs. 12.6 inch) with black calipers
Specific shocks, springs and stabilizer bars
Differential and transmission cooling
Unique Aero Package that reduces lift for high-speed stability
Michelin® Pilot® Super Sport® ZP summer-only tires† that are aggressively tuned to provide outstanding handling, grip and road-holding capability
Available Magnetic Selective Ride Control and Performance Traction Management
HD Cooling
Slotted Brake Rotors
http://www.chevrolet.com/corvette-st...ecs/trims.html
What is the "Pacific Design Package" and the "Unique Aero Package"?
Old Feb 11, 2015 | 03:09 PM
VINDIC8R's Avatar
VINDIC8R
Banned Scam/Spammer
I went for the Z51 option because I believe it is a LOT of stuff for the bucks spent. Bigger front brakes. Slotted rotors. The mag ride is not standard; it is an option (FE4). The rear vents are functional cooling the the differential and transmission. The differential is electronic slip. The tires are different than the base, not just in size. They are designed to be grippier (which means less grippy in colder temps). There is more engine cooling. Dry sump oil handling. The performance exhaust (throatier growl). Beefier sway bar, stabilizers and shocks. Different gear ratios. Aero package for better stability.
I have no plan to track the car. I just wanted the performance headroom.
  #33
Ernest_T's Avatar
Ernest_T
There are two different special packages--the Pacific and Atlantic. It takes some looking to find them, but they come with different options packages, including one with side skirts and splitter. I didn't know you could order them yet.
Old Feb 11, 2015 | 03:11 PM
  #34
Always Red Dave's Avatar
Always Red Dave
Z51 ITS OWN MODEL FINALLLLLLY! Glad you are getting one you will not be disappointed!
Old Feb 11, 2015 | 03:12 PM
  #35
Ernest_T's Avatar
Ernest_T
Thanks!
I wouldn't say your dealer is lying to you, but he may be not telling you all the details. I'd learn how the process works from the board, then go ask your dealer a lot of questions so you have the right scoop.
Old Feb 11, 2015 | 03:13 PM
  #36
Always Red Dave
MAG RIDE CONTROL worth every penny I have had it on my last 5 corvettes!
Old Feb 11, 2015 | 03:21 PM
  #37
A6T34ME's Avatar
A6T34ME
Default Prior post error??
I think the prior post stating the Pacific or Atlantic is part of the Z51 package is incorrect.
To C7 Z51 package
Old Feb 11, 2015 | 03:35 PM
  #38
grandpawmoses's Avatar
grandpawmoses
What is the "Unique Aero Package"?
I believe it's just the rear spoiler.
Old Feb 11, 2015 | 03:49 PM
  #39
Tom/99's Avatar
Tom/99
Originally Posted by nmerhaut
Don't worry about resale value. It's a very moving target. Keep listening to the responses and make a thoughtful decision. Make a list of what you really want in the car and how it should look and see what these options add to or detract from that. I can't believe you'll be disappointed with this approach.
Old Feb 11, 2015 | 03:53 PM
  #40
Ernest_T's Avatar
Ernest_T
BOWLING GREEN, Ky. – Chevrolet announced today the 2015 Corvette Stingray will be available in two new Design Packages: the Atlantic luxury convertible and the Pacific performance coupe. They go on sale later this year with the rest of the 2015 Corvette Stingray lineup.
“One of the design goals for the Corvette Stingray was to provide customers with the flexibility to tailor the car to their personality,” said Kirk Bennion, Corvette exterior design manager. “The Atlantic and Pacific Design Packages were originally designed to showcase how the Stingray could be configured as a luxury sport GT car or as a high-performance motorsport car.”
The Corvette Stingray Atlantic convertible and Corvette Stingray Pacific coupe concepts were introduced last fall at the SEMA Show. A strong response from enthusiasts helped influence production. They are the latest Chevrolet concepts from SEMA that made concept to reality. Several Camaros, such as the Hot Wheels edition, and the Sonic Dusk are now in production.
“We plan to make news with the Corvette Stingray every year, in part by offering special-edition models that offer a unique, personal ownership experience,” said Todd Christensen, Corvette marketing manager. “Our customers have told us they appreciate these limited-edition models, which have become an important part of the Corvette’s legacy.”
Luxury GT-focused Atlantic Convertible
The 2015 Corvette Stingray Atlantic Design Package is inspired by the luxury and performance of private jets seen at European vacation destinations. Offered exclusively on Z51-equipped convertibles, it is available in 2LT or 3LT trims, with the following unique features and content:
Front Z06-style splitter
Shark Gray exterior vents, hood “stinger” graphic and tonneau inserts
Chrome Torque wheels with Stingray center caps
Stingray underhood liner and floor mats
Custom splash guards, rear license plate frame and logo valve stem caps
Custom luggage.
The Atlantic Design Package is available in all colors offered on the Corvette Stingray.
Track-focused Pacific Coupe
The 2015 Corvette Stingray Pacific Design Package is inspired by West Coast drivers who attend weekend track events. It is offered exclusively as a Z51-equipped coupe, in 2LT and 3LT trims, with the following unique content:
Color choices of Torch Red, Black, Arctic White, Blade Silver and Shark Gray – a new color for 2015
Satin black full-length racing stripes
Satin black Z51 wheels with red stripe and Stingray center caps
“CFZ” carbon fiber ground effects package and visible carbon fiber roof panel
Carbon Flash rear spoiler, outside mirrors and exterior badges
Red brake calipers
Competition Sport Seats in red or black
Carbon fiber interior trim, Stingray sill plates and Stingray floor mats
Custom splash guards and rear license plate frame
Indoor car cover (gray).
As with other 2015 models, Corvette’s new Performance Data Recorder is available on the Atlantic and Pacific, as well as an all-new eight-speed paddle-shift automatic transmission. A seven-speed manual transmission is standard.
The Performance Data Recorder combines the ability to record and share drive videos with the power of a professional-level telemetry system. With included software, users can analyze their laps to improve their driving and lap times. The system includes a high-definition camera integrated into the interior’s rearview mirror assembly.
The new paddle-shift eight-speed is designed to deliver world-class shift times that rival the best dual-clutch designs, and is expected to contribute up to 5-percent greater efficiency, when compared to the previous six-speed automatic. EPA estimates are pending.
Founded in 1911 in Detroit, Chevrolet is now one of the world's largest car brands, doing business in more than 140 countries and selling more than 4.9 million cars and trucks a year. Chevrolet provides customers with fuel-efficient vehicles that feature spirited performance, expressive design, and high quality. More information on Chevrolet models can be found at www.chevrolet.com.
http://media.gm.com/media/us/en/gm/h...-corvette.html
