Coupe top pouch
Old Feb 14, 2015 | 05:06 PM
USe-car's Avatar
USe-car
Default Coupe top pouch
At one time, I read on one of the threads about a pouch or cover to protect the C7 coupe's top from damage when it is stored in the car. I've searched and can't find anything. Can anyone help me with the vendor info? Thanks.
Old Feb 14, 2015 | 05:09 PM
jrainlay's Avatar
jrainlay
As I recall, the top pouch was a GM option that could be included when ordering the car. I assume it's also available as a post-delivery accessory.
Old Feb 14, 2015 | 05:26 PM
dvilin's Avatar
dvilin
Check Mid America Motorworks they had them for the C6 not sure about the C7.
Old Feb 14, 2015 | 05:34 PM
mksz51's Avatar
mksz51
IF the top has been on the car when it's been driven it will likely be dusty. Putting dusty top into any kind of "pouch" will likely cause scratches in the top. Just put the top in as is - avoid more damage by doing that.
Old Feb 14, 2015 | 05:44 PM
pkadams's Avatar
pkadams
Corvette Central has them and they are a forum vendor.
http://www.parts123.com/corvettecent...50V&ukey=48371
Old Feb 14, 2015 | 08:35 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Spot on. Besides the cover was not designed to bag up the top while its in the trunk. It was designed to protect 1 of your 2 roofs when you bought the dual roof option and leave one roof at home.
Ant
Old Feb 14, 2015 | 08:48 PM
Rgeezer's Avatar
Rgeezer
I've got one, ordered it from the dealer I bought the car from. Looks pretty good, although not terribly well padded, so I'd still handle it with care.
Old Feb 15, 2015 | 12:10 AM
mpuzach's Avatar
mpuzach
It shows up on Chevy's web site when you "build" a car but it's not actually an orderable option.
Old Feb 15, 2015 | 01:05 AM
The top pouches I have had have been kind of a PITA to use. They are not the easiest things to get the top into due to the size (unless you have a helper) and it is just easier to put the top in the back without the pouch.
Old Feb 15, 2015 | 02:19 AM
ArcticC7's Avatar
ArcticC7
Yes they have one.
Old Feb 15, 2015 | 06:58 AM
Rgeezer's Avatar
Rgeezer
You'd really only want the pouch if you had the dual roof option. I'm not sure how you would actually get the top in the back of the car if it was in the pouch, because the roof is a pretty snug fit as it is, and the pouch is appreciably larger than the roof panel. But if you've got dual roofs, you don't want the second roof in the back as (a) you'd never have any storage space, and (b) you'd never be able to drive it with the roof off.
Old Feb 15, 2015 | 11:08 AM
bluvette2000's Avatar
bluvette2000
I have all 3 tops and 2 of the pouches. They are a GM accessory and available through any of the GM parts sources. I use them for external storage of the tops that are not being currently used and they work well. They are not useful for in-car storage. They are good quality and have the C7 flags embroidered on. The lining is very soft and if you put the top in clean it is well protected. They have handles so you can hang them from a hook.
Old Feb 17, 2015 | 09:34 AM
sting15ray's Avatar
sting15ray
I got mine from Gene at Cultrag, here:
http://www.cultragfactoryparts.com/c...el-storage-bag
Old Feb 17, 2015 | 09:22 PM
Hdhuntr01's Avatar
Hdhuntr01
http://www.ebay.com/itm/2014-C7-Corvette-Genuine-GM-Accessories-Transparent-Roof-Panel-Storage-Bag-/271514796276?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f378b00f4&vxp=mtr
This is probably what you are looking for.
Old Mar 7, 2015 | 11:59 AM
jedblanks's Avatar
jedblanks
Any tips on putting the top in the bag by yourself? I'm having a time even with a helper
Old Mar 7, 2015 | 06:21 PM
sting15ray's Avatar
sting15ray
Over time I've used three different approaches
1) lay the cover open on the ground in front of you taking care to use a towel underneath to protect from scratches and dirt - my garage floor has been epoxy sealed and is clean so I just lay it on the garage floor. Stand next to the pouch next to the opening and place the top across the flap opening of the pouch, leaning it against my legs. Lean over the top and gently pull the cover up and around the lower edge, working it back and forth until it's covered using similar motion to pulling a pillow case over a pillow.
2) lay the top on a flat soft surface (a table over a towel, pad, etc) with exterior surface down. Again, like a pillow case, gradually pull the case over one edge and work it side to side over the entire top.
3) put the top in the holder in the back of the car. While lifting the closest edge to you slightly off the car, gradually slip the pouch over the edge closest to you working it back and forth, again, like a pillow case, until fully covered.
Old Jan 23, 2019 | 02:24 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
We had a top pouch for our C5, to protect the transparent top when stored in the trunk with luggage. That was three Corvettes ago, and we haven't bought one since.
There's the dust-scratching problem, the PITA to get the top into problem, some of them are for garage storage only and won't allow you to clip the top into the trunk.
Instead, we bought one of those soft fabric rear bumper guards that you flip out over the back to protect the deck & bumper when loading/unloading luggage. In addition to its stated purpose, we can flip it forward over the luggage to keep the luggage from scratching the underside of the top. If you have luggage zippers or hardware that might cause damage, throw a towel over them before flipping the bumper protector forward.
Some of the bumper protectors are vinyl or plastic, they develop rigor mortis in cold weather, so we avoid those.
To Coupe top pouch
Old Jan 23, 2019 | 04:40 PM
hummiscorvettetaken's Avatar
hummiscorvettetaken
After reading this I just went on-line and ordered a roof panel bag through GM for storage of my second top!
Old Jan 23, 2019 | 10:36 PM
Avanti's Avatar
Avanti
Putting the top in the rather loose GM bag by oneself is not that hard if you have an adequately sized piece of clean carpet to lay the roof on, top-side up. Then simply lift the bottom edge (back of the top), slip on the bag, work it in as far as possible with the front of the roof still on the protective carpeting. Then, lift the front of the roof and finish slipping it in the bag. Viola!
Old Jan 23, 2019 | 10:48 PM
Gearhead Jim
St. Jude Donor '13
But standing on the shoulder of the road on a windy day, working by yourself, is entirely different.
It all depends on how you plan to use the bag.
