It seems pretty clear that the torque management system of the C7 means that the throttle, even in sport or track mode, is not the most linear, i.e. that 25% opening up of the throttle doesn't equate to 25% of the available performance of the engine.
I noticed this in my one test drive of a C7, in that the car didn't feel all that powerful or fast at moderate throttle inputs, only when I really layed into the throttle was the beast that the C7 is unleashed.
For those coming from very linear throttle response cars, how long did it take to adjust to the non-linear throttle response of the C7 such that it became a non-issue? Or is it something that still detracts from your enjoyment of the car?
I don't know that it's not linear, just that HP and torque take some getting used to. I've never had a vehicle break rear traction as easily, and I had C5 and C6. That's not a complaint (far from it), and I'm sure the cold temps make it more noticeable. It takes a little time to adjust to the power, but it's not at all difficult to drive smoothly.
I know exactly what you're talking about. You can get in some vehicles (especially 4 cylinders) where just touching the accelerator jumps you off the line. Usually, larger engines have more heft to the accelerator to keep that from happening (before computer controlled). When someone else drives the C7, I have to explain to them that the last 10% of the accelerator pedal represents something like 30% of the power. The car doesn't get "mean" and bark at you until you really push it down, basically telling the computer to unleash the fury.
I know exactly what Baege means. This is my first vet and expected to squeal wheels just touching the gas. You really have to stomp on it to feel the power. Different from most cars I have driven.
It's all in the programming, this is common with drive-by-wire cars. Weather/Eco/Tour are numbed down, while Sport is boosted and Track even more so. You can adjust them to your liking with tuning.
It has been common for several decades now. Lower power cars are programmed (either mechanically or electronically) to give you quicker throttle response at low rpms which makes people feel great about the street performance of their grocery getters. You may also notice that higher rpm response is dead with those vehicles.
However, if you provide the same tip in response on a vehicle that has a lot more low end torque those same people would be running the cars into trees and other cars since they couldn't handle the sudden acceleration.
As you found throttle response as well as steering feel, traction control setting and NPP are mode dependent. As you note the faster tip in is in Sport and Track. I drive in Sport Mode almost all the time and do not find the throttle setting a problem. When I get on it, it's peddle to the metal (as the old saying goes, or is it the plastic in a Vette?!). I like that steering and traction control response as well, a little tail wag before it cuts in.
Keep in mind a dyno graph (like LSx vs LTx) will not show what this thread is referring to. The dyno is full throttle only.
The OP is correct. Part throttle mapping is conservative until you get up around 75%.
Also, the stock tune doesn't allow 100% throttle under 3000 RPMs.
Trust me, recalibrating the Driver Demand (pedal) tables to "linear" values will result in way too much power when you do not want it. I jacked with my Driver Demand table for weeks and ended up very close to stock values (except for WOT).
...the last 10% of the accelerator pedal represents something like 30% of the power. The car doesn't get "mean" and bark at you until you really push it down, basically telling the computer to unleash the fury.
Glad to hear it. I'm still breaking mine in and haven't applied more than about half throttle nor exceeded 3000 rpms, so I know I have something to look forward to.
Nice to know that the way it's tuned from the factory works well, as the car is such a beast that a more linear throttle might not be the safest. I guess it's a compromise that has to be made with so much power on tap. It does allow you to be more precise and intentional in unleashing that power.
I second that, hence why my car is on "all fours" waiting for wheels and suspension parts from my little incident. After installing the CAI and the throttle body spacer, the rear end will brake away with the slight touch of the throttle and yes cold weather did not help much.
I was doing 30-35 mph, when I decided to accel to avoid someone. The rear end just took off from under me and wipped me to the center divide. It will take some time to get use the way it accel or get new tires.
It makes for a more comfortable drive until you open her up.
another good way to look at it as a positive feature.
I think it's a very positive feature and a safety feature. This happened to me and after I thought about it I was glad the T-response - nannies were there:
In middle lane of three lane busy freeway. I was coming up slowly on a car in front of me, I glanced in left side mirror and started to change to the left lane to pass. As I overtook the car in front of me and was half way into the left lane (too late to not change lanes) I was startled by a car going probably 10/15 Mph faster than me. Guess I just didn't see him coming. He flashed his brights as I was pretty much cutting him off and it probably pi***ed him off. I stabbed the throttle probably half way down (going about 65mph). The tires broke a little (damp cool) and nannies came on allowing me to maintain control and not get sideways. With a strictly linear throttle I don't think it would have been a good outcome.
