How to change the oil on the A&A supercharger C7
Miles are up.need to change the oil in the A&A unit for my c7.
Does anyone have pictures/file/tips for the first oil change of the a&a supercharger?
Many thanks
Many thanks
C7 of Year Finalist (performance mods) 2019
Stupid easy ,jack up front end, pull plug on top of head unit, the one with little dipstick. Undo nut at end of drain tube. Let it drain fully. Tighten up nut on drain tube. Insert supercharger oil tip with oil in top hole where you previously took the plug out (you need to cut tip so oil can flow out). Let it drain into head unit. Reinstall plug, take care of jack....done
