I went out to buy an SD card for my 2015 that will be built next week. When I got to the display I saw many speed options, with increasing prices for increasing speeds. Can the Corvette infotainment system take advantage of the faster speeds? Or would any old card do? What about the PDR?
They were cheap enough that I just went with a mid-range 320X/48MB/sec card to start with, but I wouldn't mind getting a faster one if it will help performance -- especially if it needs to re-index every time the car starts.
Don't think you'll see much (if any) speed differences. Recording at less than HD shouldn't be much of a task for any modern SD card. That being said, it doesn't cost much more for a Class 10 card which you may want to use in other devices later.
The higher the class number, the faster the card can read/write. This gets to be important in cameras, especially in taking high resolution pictures (and could be an advantage with the PDR, I'm not familiar with it's specs). For audio playback, a class 6 will work just fine but for $5 more, get the class 10.
In the photograph above the class is the "10" in a partial circle.
I have found some SD cards just won't work. The two piece kind I have had no luck with. I now have a 32GB class 10 one piece card and it seems to be working well now.
This is what is in my car and working for me in my PDR..
http://www.ebay.com/itm/New-32GB-SDHC-Class-10-Flash-Memory-Card-32G-SD-HC-SDXC-Ultra-High-Speed-Camera-/281363658449?pt=LH_DefaultDomain_0&hash=item418294b6d1
I think everyone has agreed that a Class 10 is THE choice for the PDR, might even be mentioned in the Owner's Manual but I don't remember.
Yes Rick the manual calls for a Class 10 for the PDR. Not sure about audio, but for a few dollars more I will get mine all the same. Must be Fat 32 formatted!
Reason: Additional info
Are you saying it wont record to the SD card without formatting the SD?
I just put a 4GB Class 10 SD card in with 427 "Oldies" songs since I'm going to drop XM radio. As soon as I get in the car it starts playing the shuffle sequence where I left it when I shut down! Faster than XM! I took that SD card from my digital camera and bought a 16 GB Class 10 to replace it for $10.
Most cards are pre formatted but there are more than one format (different types of cameras use different formats). The Vette likes the FAT32 format. If you don't know, just stick it in a computer & reformat it choosing FAT32.
If you want to format a SD card that is 64Gbs or above, Windows can not do it alone, you will need to find a utility (Search the net) called guiformat and it will do the trick.
Will the car accept a 64 GIG Sd Card? I am going to Best buy today to get me a few SD cards for the car. I would prefer the 64 over the 32 for the PDR, but all I have seen says 32 gig...
Has anyone tried NTFS format? The owner's manual for my 2015 says, on page 20 of the infotainment system, "Supported file systems are FAT32 and NTFS." I think I'll try the NTFS format and see what happens. This file system has some advantages over the older FAT32, though I can't remember what they are at the moment.
To answer the original question .. yes .. speed matters. Get a class 10 card ... the benefits are obvious when a) writing songs to the card and b) when the car indexes the contents in order to show the onscreen data ..
Frodo,
I think the difference is the Infotainment v the PDR system itself. The OM page 7-1 only gives an option for a FAT (File Allocation Table) 32 for the PDR.
However I agree,having done a brief search on the ole interweb, it seems that the New Technology File System (NTFS) is better and faster in PC machine, however it is not very compatible with Linux or Mac machines. Since the Infotainment is PC based (I Believe) that should not be a problem, unless you are using a MAC at home...
I am planning to buy the same SD Card for the audio and formatting the same for interoperablity with both systems.
FAT32 only supports file sizes of 4GB or less and up to 2TB partitions. NTFS they say is faster on benchmark. Don't know much about the PDR on the stingray, file sizes etc. so can't say if the NTFS would provide any advantage since i'll assume the file sizes will not exceed 4GB. In the computer world NTFS has the advantage.
I appreciate the comments about class 10, and I did get a class 10. But there appear to be multiple speeds of class 10, too. For example, one poster posted a picture of an 80 MB/s card as class 10. But mine is only 48MB/s. Would it be better if I spent the extra money and got an 80 MB/s or higher class 10 card?
NTFS is Microsoft format and is only compatible with newer windows operating systems. An SD card formatted with NTFS will not work in the PDR or most other non Microsoft products.
Most 32GB SD cards come formatted with FAT32. 64GB and larger cards typically come formatted in exFAT. The PDR will not read exFAT formatted cards either. You can reformat a 64 or 128 GB card to FAT32 with a number of different software products.
Just keep in mind 32GB SD cards are cheap. 64's are coming down in price but 128's are FAR too expensive at this point.
I just went to Best buy. They are having a sale on their website and will price match. I got a Sandisk Extreme Plus 32G, Class 10, 80 MB/S. I picked them up for 35 bucks a piece. I also got a Pro 32G, C10, 95 MB/s for 39 bucks due to Amazon.com pricematch...
Best Buy guy says the hgher speed is better for music...dont know if that means it doesn't matter for video or what...
IMHO, I would go get the higher MB/s if I were you...
