Starting a C7 Corvette @ –26F
Old Feb 20, 2015 | 02:42 PM
corvettecop's Avatar
corvettecop
Default Starting a C7 Corvette @ –26F
I can't imagine . . .
http://blog.caranddriver.com/analysi...y-to-start-it/
Old Feb 20, 2015 | 03:12 PM
Lacoven's Avatar
Lacoven
mine said -18 this morning.
Old Feb 20, 2015 | 03:58 PM
RickMN's Avatar
RickMN
The car in the article was a Z51. Not surprising that the oil took a while to come up to temp. One of the tradeoffs of the external oil reservoir is that it sucks more heat out of the oil even when you don't want it to.
Not sure why the manual transmission gets so stiff in cold weather. Sounds like the one actual complaint that should be easy for GM to fix if they tweak the oil/grease in question.
Old Feb 20, 2015 | 04:58 PM
Red C8 of Jax's Avatar
Red C8 of Jax
Wonder how the A8 would handle the -26 deg temp?
Old Feb 20, 2015 | 05:10 PM
mjw930's Avatar
mjw930
The Tremec is already running DEXRON III ATF instead of true gear oil so it's about as light as it can get.
Old Feb 20, 2015 | 05:40 PM
Rad22's Avatar
Rad22
They usually do, but wonder if C&D put winter tires on the test car. Wouldn't want to trust the summer compound again after exposure to THAT temperature.
Old Feb 20, 2015 | 05:52 PM
slesher's Avatar
slesher
Been one of the coldest winters ever. Mine said -3 this morning but warmed up to 5!
Even with these awful temps the stingray has been as reliable as a Honda even with mods
Old Feb 20, 2015 | 10:30 PM
c7v's Avatar
c7v
Without a problem, I keep mine outside and it was close to that temperature for a couple of days. I start it from inside the house and when I come down stairs 7 to 10 min later it's at 180-200 degrees.
Old Feb 20, 2015 | 11:12 PM
C7Joy's Avatar
C7Joy
My car hasn't seen the light of day since mid-November. It's enduring 20F under its flannel blanket in my garage. Getting eager to pull the cover but there is no sign of a thaw. Then there will be weeks of melting and slop, and potholes!!
Old Feb 21, 2015 | 12:01 AM
Gr8ful's Avatar
Gr8ful
Vehicle hybernation, Bummer. Great reason to move to Florida, even though it in the 30s last night.
Old Feb 21, 2015 | 12:32 AM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
they don't make block heaters for these ****'s, luckily our winter hasn't been too bad.
Old Feb 21, 2015 | 05:41 AM
beltfed21's Avatar
beltfed21
No worries, mine is sitting in a 60 degree heated garage, covered, with the battery plugged in.... Far to much salt on the roads to take it out! Winter sucks!
Old Feb 21, 2015 | 12:46 PM
W88fixer's Avatar
W88fixer
That’s surprising, would think the aftermarket would fix that before too long. Starting any vehicle at -26 that hasn’t had a block heater running is hard on the engine, more wear.
Other than that, hopefully a heated garage which could keep the temps above freezing inside.
I’d rather be hot any day than freezing my *** off. Don
Old Feb 21, 2015 | 03:37 PM
fireinv38's Avatar
fireinv38
Are all you using the stock tires. 2 degrees in nj.no issues. Car started, tires have not delaminated. Normal speed driving. No issues.
Old Feb 21, 2015 | 03:54 PM
iclick's Avatar
iclick
What oil viscosity do you guys in the frozen North use in winter?
Old Feb 21, 2015 | 04:28 PM
mikez06's Avatar
mikez06
Mobil 1 5W-30. But the car basically hibernates. Can't and won't drive it in the snow/salt/below zero temps. Yes, we know what we're up against in these NorthEast winters. SUX...but again...we know.
Old Feb 21, 2015 | 05:34 PM
Jefff1's Avatar
Jefff1
I forgot I even had a Vette.this winter
To Starting a C7 Corvette @ –26F
Old Feb 21, 2015 | 06:04 PM
energystar's Avatar
energystar
I don't have a vette yet but with my daily driver a 2002 Neon and my 99 Camaro SS I turn the key to on and don't crank them over till the fuel pump stops and this I do year round and they start right away...this past week it's been around -27C and no problem starting...can you do that with the vette or will it not allow you to first start the fuel pump...also the lowering the window to open the car is the stupidest idea an car manufacture can come up with because of winter temperatures can freeze a window from opening.
Old Feb 21, 2015 | 06:35 PM
nice1huh's Avatar
nice1huh
Default oil heater
Back in the mid 60s I had a triumph GT6. In the winter (lived in ohio then
I had electric dip stick worked good
Old Feb 21, 2015 | 06:57 PM
AFVETTE's Avatar
AFVETTE
Not my Vette, but our Volt at -16. Easy peasy
