EasyPower Radar Cords Now Available For Your C7!
Old 02-22-2015, 10:56 PM
0corvettemods1
Former Vendor
corvettemods1's Avatar
St. Jude Donor '12-'13
Default EasyPower Radar Cords Now Available For Your C7!
If you're tired of the coiled power cable that came with your radar detector bouncing around when you drive....THEN YOU'RE NOT ALONE!
Our power cable plugs into the power supply of the rear view mirror and is tucked away out of sight when installed.No need to plug and unplug your radar detector anymore! The cable will automatically power your device on and off when you start and turn the car off. SIMPLE just like it was intended to be!
Our cable is designed to work with all Corvettes & Our new EasyPower Cord works with:
ESCORT-ALL MODELS
BELTRONICS-ALL MODELS
VALENTINE MODELS- ALL MODELS
If your current detector uses the phone plug type connector then this will work for you. The EasyPower cable is 8 inches in length which we have found to be just enough to mount the detector around the mirror without any extra cord hanging around to disrupt your view.
We also stock a 12 inch cable for an extra $4 per order. If you wish to order the longer cable, please specify by selecting above.
On Sale For $14.99! Click below to order:
http://www.corvettemods.com/Corvette...er_p_4982.html
Before:
After:
corvettemods1 is offline
Old 02-22-2015, 11:02 PM
motomanvette
motomanvette's Avatar
Is this cord for the C7 any different than the one I bought and used for my C6?
motomanvette is offline
Old 02-22-2015, 11:19 PM
0corvettemods1
Former Vendor
same principal, we've changed our supplier of the cord for a better fit to the mirror.
Old 02-22-2015, 11:51 PM
9ball1104
9ball1104's Avatar
Is there an installation manual? The description makes it sound very simple. I remember seeing a post here showing how to install quick connectors step-by-step. The OP did a great job and made it sound easy, but there were a lot of details like how to accomodate for the very snug quick connector connections. There was another post of a guy who had it done professionally and afterwards his side mirrors didn't dim any longer or they were always dimmed. Not sure which. Don't know what kit they used but it might have been this one. This seems like an ideal way of connecting a radar dectector if u don't end up breaking something. There was also a post stating GM said not to tap into the rear view mirror for power. I'd be really unhappy if I broke something.
9ball1104 is offline
Old 02-23-2015, 06:57 AM
grandpawmoses
grandpawmoses's Avatar
Is there an inline fuse?
grandpawmoses is offline
Old 02-23-2015, 09:17 AM
0corvettemods1
Former Vendor
No, that circuit is aleady protected with a 10 amp
Old 02-23-2015, 09:50 AM
PUGPROUD
PUGPROUD's Avatar
I believe I read somewhere that the back of the mirror on the convertible doesn't detach as on coupe and that this will not work on them...if I'm mistaken can someone clarify please.
PUGPROUD is offline
Old 02-23-2015, 01:01 PM
StingRaycer
StingRaycer's Avatar
I thought earlier forum posts stated the power to the rearview mirror was not enough to safely run the detectors on a wire tap.
StingRaycer is offline
Old 02-23-2015, 01:29 PM
Mr Snappy!
Mr Snappy!'s Avatar
That is because the early attempts tried to use the dome light connection. The power out of the plug produces plenty of power and does NOT trip any fuses or relays.
Mr Snappy! is offline
Old 02-23-2015, 07:54 PM
motomanvette
Are instructions available online for the C7?
Old 02-23-2015, 09:39 PM
grandpawmoses
I didn't have a problem with my vert.
Old 02-23-2015, 09:40 PM
grandpawmoses
Old 03-29-2015, 11:47 PM
chipsvette06
chipsvette06's Avatar
How about a video on install. Many might buy if it looks doable.
chipsvette06 is offline
Old 03-30-2015, 01:44 AM
mark1107
mark1107's Avatar
St. Jude Donor '14-'15
Ditto!
mark1107 is offline
Old 03-30-2015, 04:49 AM
DJDoubleA
DJDoubleA's Avatar
DJDoubleA is offline
Old 03-30-2015, 06:48 AM
slesher
slesher's Avatar
slesher is offline
Old 03-30-2015, 10:42 AM
VetteLT4
VetteLT4's Avatar
Originally Posted by slesher
VetteLT4 is offline
To EasyPower Radar Cords Now Available For Your C7!
Old 03-30-2015, 08:50 PM
bullybully1
bullybully1's Avatar
bullybully1 is offline
Old 03-30-2015, 08:56 PM
0corvettemods1
Former Vendor
sorry guys no videos at the moment, but in reality its not needed. Install is quite simple and straight forward.
Old 03-30-2015, 09:28 PM
bullybully1
Then describe the procedure please
Quick Reply: EasyPower Radar Cords Now Available For Your C7!
