Headlight Protection
Old Feb 23, 2015 | 08:02 AM
OrioleFan's Avatar
OrioleFan
Default Headlight Protection
Any suggestions on how to protect the glass on the headlights from chips or scratches?
Old Feb 23, 2015 | 08:19 AM
mikez06's Avatar
mikez06
Since I always get tinted windows, I also get clear tint on the headlamps at the time.
Old Feb 23, 2015 | 08:46 AM
beepster's Avatar
beepster
My Expel installer put a kit over mine. Have since heard that the heat absorption may cause the headlamp cover to crack. I will be interested in any insight on this.....
Old Feb 23, 2015 | 08:51 AM
Rave's Avatar
Rave
XPEL Headlight kit at: http://www.xpel.com/products/headlig...79&series=1806
Old Feb 23, 2015 | 09:13 AM
W88fixer's Avatar
W88fixer
Paint film does a great job of protecting the headlight assembly from chips and rocks and such. Also keeps them from getting ugly and hazing up.
Damage the headlight exterior? Certainly not with 12 yrs experience on two cars I’ve used it on. The C7s headlight material may well be much different, I don’t know but I’d think GM would not have spec’d material that is so intolerant of heat. I have XPEL on my C7 and it suffered no ill effects in 2014’s summer in central TX. Don
Old Feb 23, 2015 | 10:41 AM
VETJAZZ's Avatar
VETJAZZ
I also put Xpel headlight protection on mine.
Old Feb 23, 2015 | 11:14 AM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Had it on my C6's headlights and no problems in over 83K miles. Have it on my C7 and no problems in over 17K miles
Old Feb 23, 2015 | 12:15 PM
Zymurgy's Avatar
Zymurgy
Moderator
GM (and other manufacturers) have issued TSBs on headlight cracking:
The bulletin is being issued to make dealers and customers aware of chemical damage that may be caused to exterior polycarbonate headlamp lenses. Most late model vehicles have these types of headlamp lenses. This material is used because of its temperature and high impact resistance.
A variety of chemicals can cause crazing or cracking of the headlamp lens. Headlamp lenses are very sensitive. Care should be exercised to avoid contact with all exterior headlamp lenses when treating a vehicle with any type of chemical, such as those recommended for rail dust removal. Rubbing compound, grease tar and oil removers, tire cleaners, cleaner waxes and even car wash soaps in too high a concentration may also attribute to this condition. This could result in the need to replace the entire headlamp housing.
Warning
Use only lukewarm or cold water, a soft cloth and a car washing soap to clean exterior lamps and lenses.
Care should be taken to not cover headlamps with shop mats or fender covers if the vehicle is being serviced with the headlamps or DRL illuminated. Covering an illuminated lamp can cause excessive heat build up and crazing/deformation of the lens may occur. The degradation of the lens can be unnoticeable at first and eventually become hairline cracks in the lens. In extreme cases, it could cause the lens to deform. This damage can also be caused by aftermarket shields that are often tinted in color.
Once a heat buildup is generated by the headlamp, a degradation of the headlamp lens begins. This degradation of the lens can be unnoticeable at first and eventually manifest as spider cracks. In more extreme cases, it will begin to melt the lens of the headlamp.
Notice
Headlamps damaged by chemicals, improper cleaning, or overheating due to being covered are not covered under the new vehicle warranty.
Old Feb 23, 2015 | 12:25 PM
mikez06's Avatar
mikez06
I've been aware of this particular TSB. Which is why I put clear tint on the headlamps that don't totally cover every single 1/4 inch, leaving edges to 'breathe' per se. Never had an issue, done this with all of these very low cars.
Old Feb 23, 2015 | 12:28 PM
Bunk's Avatar
Bunk
It is clearly best not to cover the lights. Thank you for this bulletin.
Old Feb 23, 2015 | 12:36 PM
Rave's Avatar
Rave
I should probably add that my XPEL installer recommended not installing XPEL on the headlights. Reason being, he stated he has seen XPEL actually delaminate hightlight housing plastic on a 911, when the XPEL had to be removed. (I didn't ask why it had to be removed). I decided not to cover my headlights in XPEL. I figure if debris hits them hard enough to do damage, that's what insurance is for.
Old Feb 23, 2015 | 02:06 PM
boxster99t's Avatar
boxster99t
(and in my case I have xpel on the bumper, entire hood and front fenders). Haven't cracked a headlight lens ever.
Old Feb 23, 2015 | 04:29 PM
FlashofRed's Avatar
FlashofRed
I had no intent of having Xpel installed on my headlamps but my Xpel installer recommended it so I did it. I most likely would not have done it if I knew about it possibly causing damage. I think I'm going to contact the installer and see what he has to say because he comes very highly recommended and has been doing this for a very long time.
Old Feb 23, 2015 | 04:40 PM
nmerhaut's Avatar
nmerhaut
Have had clear bra on three Vettes and NEVER had the cracking some claim. Don't think it's a problem.
Old Feb 23, 2015 | 04:59 PM
I would probably follow GMs recommendation, but I can see the concern about damage to the exposed headlight covering.
To Headlight Protection
