Pdr
Old Feb 24, 2015 | 01:32 PM
sprk33's Avatar
sprk33
2018 Grand Sport
Default Pdr
I have a 2Gig PNY optima sd card that I formatted for FAT32. The card allows me to copying pics to it. However, when I put it in the sd slot in the glove box the PDR in the car is not recognizing it. I have formatted the card several times thinking it did not take. Has anyone had problems with it not recognizing their SD card ???? Is there a special SD card that needs to be purchased??
Old Feb 24, 2015 | 01:57 PM
rogergcam's Avatar
rogergcam
I don't think the PDR will recognize the slot in the box between the seats. Try the slot in the box in front of the pax seat, on the left hand side of the box...
Old Feb 24, 2015 | 02:00 PM
RicK T's Avatar
RicK T
I've read here that 8gb is the minimum size card.
Old Feb 24, 2015 | 02:07 PM
alienranch's Avatar
alienranch
This could be the problem. You wouldn't want to use something as limited as a 2gb card anyway. 32/64 is ideal.
Old Feb 24, 2015 | 02:19 PM
sprk33's Avatar
sprk33
2018 Grand Sport
I got it....search was my friend...finally saw where had to download a format program that windows partiions the SD disk. I downloaded a SD formatter and it work like a charm. Thanks for all inputs.
Old Feb 24, 2015 | 04:22 PM
Woodson's Avatar
Woodson
Putting in the right place probably helped as well.
Old Feb 24, 2015 | 06:32 PM
sprk33's Avatar
sprk33
2018 Grand Sport
naa was in the pooka....just wasn't reading the SD card....I made sure I was in right hole lmao didn't want to be one of those...that's like not turning the on/off switch to the on position lmao
Old Feb 24, 2015 | 09:09 PM
Woodson's Avatar
Woodson
My bad reading skills.
Old Feb 25, 2015 | 04:30 PM
iclick's Avatar
iclick
I temporarily have a 4gb Mini in an SD adapter installed now and it works fine. Just received a 32gb SD that I'll be using from now on.
Old Feb 25, 2015 | 07:30 PM
alienranch's Avatar
alienranch
Default Pdr
Still, get yourself a larger card for longer video retention. $10 will get you 16gb.
To Pdr
