HD Dash Cam
Old Feb 26, 2015 | 05:32 PM
Z33 to a C6's Avatar
Z33 to a C6
Default HD Dash Cam
Anyone out there using an HD dash cam? I wouldn't splurge $1700 for the PDR. Just curious if anyone can recommend any particular brand/model that works well.
Old Feb 26, 2015 | 05:49 PM
alienranch's Avatar
alienranch
Default HD Dash Cam
That $1700 includes navigation as well, not just PDR.
Old Feb 26, 2015 | 07:48 PM
GeoV55's Avatar
GeoV55
I have a Garmin VIRB. I use it for cycling and on my boat. Can add Speed, Direction and elevation to your video. Can also be paired with your phone to send tracking info to Facebook so friends will know where you are at.
Old Feb 26, 2015 | 07:54 PM
11B250's Avatar
11B250
this site has alot of good info...
http://dashboardcamerareviews.com/
based on that website, I decided this is the one I would get as of today
http://amzn.com/B00PPYDAXA
Old Feb 26, 2015 | 08:04 PM
Jordan M's Avatar
Jordan M
I had the same reservations when I ordered my 15. So I found and bought the BlackBox G1W DashCam. Shoots 1080P at 30FPS, and looks pretty good. It doesn't have too many of the advanced PDR type features; but records good video and audio; all for under $50.
Created a vid driving around my old neighborhood that you can check out.
Old Feb 26, 2015 | 08:11 PM
buckeye4's Avatar
buckeye4
I have a Mini 805 dash cam hardwired next to my V1. Basic HD GPS recording with sound.
Old Feb 26, 2015 | 08:19 PM
CRABBYJ's Avatar
CRABBYJ
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
I also have this one but without GPS. I use a 32GB card as suggested but some have even gone with 64GB with no problems. The video is excellent and it is small enough to hide somewhat behind the rear view mirror. This Spring I plan to route the power cord to hide it better.
Old Feb 26, 2015 | 08:59 PM
nmvettec7's Avatar
nmvettec7
HD dash cams can be found all over ebay for under $60.00.
Old Feb 26, 2015 | 10:06 PM
rocket68's Avatar
rocket68
I have a Garmin Dash Cam 20. Records in HD, shows location, speed, and looks very good to me. Check out the specs on Garmin's website.
Old Feb 28, 2015 | 04:35 PM
Cpenque's Avatar
Cpenque
How did you mount your Virb? Did you use a Ram Mount or one of the Garmin suction mounts?
Old Aug 8, 2016 | 08:59 PM
brochild's Avatar
brochild
6th Gear
Hi Buckeye4, if I may ask, how did you hard wire your dash cam?
I have an escort Max with a blendmount using the mirror tap. I wanted to modify this to also include power for a dash cam. Have not figured that out yet
Old Aug 8, 2016 | 09:22 PM
Millerrock's Avatar
Millerrock
Go pro!!
Old Aug 8, 2016 | 10:10 PM
springer-'s Avatar
springer-
$300 and includes navigation that doesn't require a subscription. Dash cam works great.
http://g.factoryoutletstore.com/cat/...FQ6PaQodEGoC4Q
Old Aug 9, 2016 | 09:51 AM
buckeye4's Avatar
buckeye4
You need to convert a 12 volt source to a 5 volt USB connector. I used this adapter tapped to the 12V line (fuse #37 in rear) I used for my radar dectector. I did not use the mirror tap configuration for my V1.
https://www.amazon.com/dp/B00BMIVFK8...74WERN1XHQQJVC
Old Aug 9, 2016 | 03:04 PM
bbdmac's Avatar
bbdmac
I second the Black Box B40C. I have a generic version of this camera (there are many of them that use this same basic camera body) and it works great. The video is very high quality and with a 12 to 5V converter it powers on and off along with the vehicle and just keeps overwriting the files once the card is filled up. Can't beat it for the small price.
Old Aug 9, 2016 | 05:32 PM
Car#30's Avatar
Car#30
After some crazy SOB road raged on me a couple months back I decided to get a dash cam. I bought the KD Links X1 on amazon for $165. HD with a 165 degree camera view. It has GPS and a bigger screen that I can actually see plus I liked the software that shows time, date,
speed, location, and a map of where you traveled during each 5 minute clip. With a 32GB chip it records for 5 1/2 hours with sound.
Old Oct 19, 2016 | 04:24 PM
sabasigh's Avatar
sabasigh
So if i use a mirror tap to power a dashcam and that mirror tap is only on when the ignition is on...it looks like i would need to power up the dash cam via the power button each time?
Not sure the dash cam boots every time it senses power...I am waiting on a Rexing V1P
To HD Dash Cam
Old Oct 19, 2016 | 04:26 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
I have a Compustar, front and rear, $300 CDN installed....seems to work well, I like the event recorder when it's parked.
Old Oct 19, 2016 | 04:36 PM
427Z0SX's Avatar
427Z0SX
Anybody looked at Black Vue?
I'd like a dash cam that not only records when I drive, but also when the car is parked and I'm not there. You never know what can happen in a parking lot.
Thanks,
Old Oct 19, 2016 | 05:31 PM
chronage's Avatar
chronage
That's so much sharper than PDR
