Stingray Emblem alignment stencil
Mar 14, 2015 | 12:58 PM
Rainy day - thinking about warmer weather when I can change over my emblems to the carbon flash black ones. Thought I would try to create a stencil/template to help with the alignment of the Stingrays. Used the new ones to trace an outline on a manila folder. Taped it to my wife's cutting board and cut it with a utility knife. Test fit on car - perfect!
But now, I have to figure out how to remove the existing emblem with the stencil on the car. Maybe it will work. Just wanted to post a potential tip. Will try to remember to post results.
Mar 14, 2015 | 01:00 PM
I never had a problem using a line of painters tape,
tip: the fish does not go on paralell to ground, it tilts down at the head
Mar 14, 2015 | 02:05 PM
Painter's tape was my original plan and its simpler than this. I was bored
Know about the stingray not being parallel with ground. The one that I am most concerned (but not much) is the "corvette" script on the rear.
Thanks.
Mar 14, 2015 | 02:07 PM
Quote:
Originally Posted by
C7cmnthru
. I was bored
been there...
just do a square of painters tape around the rear
before you saw off the chrome original...
Mar 14, 2015 | 03:18 PM
Carbon Flash Emblems
I just switched my chrome emblems out for the carbon flash emblems.
I used kite string to run behind the chrome emblems to remove them after I used a blow dryer to heat it up a little.
The worst part of the job was removing the old adhesive.
I used painters tape around the stingrays.
The front was easy because of the indent.
Mar 14, 2015 | 03:32 PM
What did you use on the chrome grille bar?
Sallye M
Attachment 47871004
Attachment 47871006
Attachment 47871005
Mar 14, 2015 | 04:29 PM
C7cmnthru
I used electrical tape and a credit card to press the edges into the grooves top and bottom. Looks decent. May redo it when it's warmer
Mar 14, 2015 | 07:33 PM
I used vinyl tape strip to cover the chrome strip on the grille but then I had a very good friend switch out my grille to a Z06 grille!
Reason: typos
Mar 14, 2015 | 08:44 PM
Glen e
Bingo ....PT is the down and dirty way...works flawlessly...
Mar 14, 2015 | 11:03 PM
Painters tape does work very well.
