First Glitch
Old Mar 25, 2015 | 01:40 PM
LB001's Avatar
LB001
Default First Glitch
I have an A8 coupe, bought in Dec.2014. It's been running perfectly until this morning. I started the car for the first time today, and put it in reverse, to back out of my garage. As I fed power, I could hear the engine accelerate, but the car did not move. I tried shifting from drive to reverse, and neutral to reverse, with no luck. I shut off the engine, and again tried shifting gears; all of a sudden I felt or heard a loud thunk, as the car lurched into reverse. I've used the car on and off, all day with no similar occurence.
Has anyone else experienced this? Anyone have any ideas as to the cause? I'm reluctant to take it to the dealer until or unless it happens again.
Old Mar 25, 2015 | 02:08 PM
HighTeq's Avatar
HighTeq
Stuck brake rotor?
Old Mar 25, 2015 | 03:06 PM
Woodson's Avatar
Woodson
Originally Posted by HighTeq
Stuck brake rotor?
did you wash it last night?
Old Mar 25, 2015 | 04:50 PM
LB001's Avatar
LB001
Yes. The last thing I did before putting it in the garage yesterday was to wash it. Could hosing the wheels cause a brake to freeze?
Old Mar 25, 2015 | 04:58 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Yup, the rotor will rust up like a 50 year old piece of iron! If it "blooms" enough, it'll cause the rotor to freeze up in the caliper pad.
You need to get mean with it to free it up. Better yet, after washing blow the rotors with a leaf blower and then go around the block heating up the rotor and drying everything off real nice before putting it in the garage for the night.
Elmer
Old Mar 25, 2015 | 05:01 PM
HighTeq's Avatar
HighTeq
Yes, the rust created from the wash will lock them up. I'd recommend drive it around the block to remove any water/rust build up before putting it away for the evening.
Good thing is, your transmission is fine.
Old Mar 25, 2015 | 05:08 PM
kenownr's Avatar
kenownr
Old Mar 25, 2015 | 06:34 PM
sTz's Avatar
sTz
Related story: https://www.corvetteforum.com/forums...y-i-think.html
Old Mar 25, 2015 | 09:12 PM
W88fixer's Avatar
W88fixer
I understand what the responders are saying, however, I’ve never had anything like that happen and I’ve never paid attention to drying the rotors after a wash or driving it around to heat the rotors.
The worst I’ve even had in decades of disc brake cars is a very slight, very brief “tug” from the rotor and/or squealing on first application. Don
Old Mar 25, 2015 | 09:53 PM
Had that happen before. I now drive the car after washing it to get the rotors and pads dry.
Old Mar 25, 2015 | 10:12 PM
MikeC4C5C6...C7's Avatar
MikeC4C5C6...C7
Same experience, same "cure".
Old Mar 25, 2015 | 11:17 PM
mpuzach's Avatar
mpuzach
This thread is a perfect example of the excellent help that's so often provided by members of this forum.
Old Mar 25, 2015 | 11:30 PM
FLS2K's Avatar
FLS2K
My C7 has done this once...only washed three times in the first 4 weeks. My S2000 did it all the time back in the day. That's your "problem." Sleep well.
Old Mar 26, 2015 | 01:25 AM
Da Hawk's Avatar
Da Hawk
I always drive it around for 5 minutes or so right after I wash it to prevent this very same thing from occurring. Plus, it allows the water spots to bead off the car which means less drying with the towel in the end.
Old Mar 26, 2015 | 07:11 AM
C7Joy's Avatar
C7Joy
The quick rusting of the brake rotors is a PITA. After I was, I hit them with the blaster to get most of the water off. Then before backing into the garage I run the car aggressively forward and backward in my driveway so I can do several hard brake applications. It usually does the trick. I have had a few brake seizures but they always pop loose.
Old Mar 26, 2015 | 10:32 AM
vettesome's Avatar
vettesome
I was moving my ZL1 yesterday, last put away right after wash, and the exact same thing happened. It is not uncommon.
Old Mar 26, 2015 | 01:35 PM
LB001's Avatar
LB001
My sentiments exactly. Thanks to all who responded. This forum is a great source of information.
To First Glitch
Old Mar 26, 2015 | 08:46 PM
meyerweb's Avatar
meyerweb
If you have to put it away with wet rotors, just leave it in gear, or park, without using the parking brake. (Unless, that is, you have to park on a hill.) The rotors will still get rusty, bat at least the pads won't freeze to the disk.
Old Mar 26, 2015 | 11:09 PM
mpuzach's Avatar
mpuzach
I never set the parking brake in the garage but my pads still stick to the rotors after every wash.
Old Mar 27, 2015 | 11:15 AM
LisaVette98's Avatar
LisaVette98
My Camaro has done this before but appreciate the information as to drying the rotors! Funny that I've never had it happen with any other cars but will be forewarned when my Stingray comes in!
