Balnk DIC Solution
Old Mar 26, 2015 | 12:08 PM
JVJaz's Avatar
JVJaz
Default Balnk DIC Solution
Has anyone experienced a problem with the gauge cluster going completely dark - no digital, no analog? I've experienced this problem 2x with my 2014 Z51. After shutting the car off and leaving it alone for a period of time, it begins to work again. Strangely, the center screen for radio, NAV and such worked just fine. Any thoughts would be appreciated.
Referring to my above highlighted earlier post, I went to the dealer yesterday and they found that Chevrolet just released a new IPC software update which corrected the DIC problem. For those who replied to my original post, thank you very much. For those who are experiencing this problem, you may want to inform your dealer of this update, saving you and them the headache of replacing the screen.
Old Mar 27, 2015 | 10:03 PM
First Z06's Avatar
First Z06
Thanks, I had the same issue at 150 miles. The dealer replaced the entire DIC which did not solve the problem. The folks at GM Tech in Detroit asked me for a video of the sequence of events leading to the dash going blank. (I could duplicate it with regularity by opening the rear hatch before opening the driver side door, then closing the hatch.) They were able to duplicate it on 2 vehicles in Detroit and promised to be working on it over the months mine would be in storage for the winter.
It looks like they have found the problem. Could you let me know what is Chevrolet's IPC # so I can let them know in a couple of weeks when I take mine in.
Richard Whitney
Westerville, OH
Last edited by Steve Garrett; Jul 5, 2015 at 11:36 PM. Reason: No need to requote the OP, especially when you're the next poster.
Old Mar 28, 2015 | 12:25 PM
JVJaz's Avatar
JVJaz
Richard Whitney
Westerville, OH
Richard, will be happy to but it will have to wait until Monday as my service order record is in my office. Take care, john
Old Mar 28, 2015 | 12:33 PM
ArcticC7's Avatar
ArcticC7
Slap him around a little he'll wake up and come to life. Just don't use any harsh "solution" on it, DICs can do this from time to time...
Old Mar 30, 2015 | 12:11 PM
JVJaz's Avatar
JVJaz
Richard Whitney
Westerville, OH
Unfortunately, there was no IPC code # on the service record and, to add insult to injury, it resurfaced this morning. I opened the hatch before the driver's door and had no DIC. I give up as apparently Chevy doesn't have a clue of what they're doing. Sorry.
Old Mar 30, 2015 | 12:14 PM
Woodson's Avatar
Woodson
Did you use the button on the outside of the car? I was told in another thread that might be the issue. I've stopped using that button and have not had the problem since.
Old Mar 30, 2015 | 12:16 PM
JVJaz's Avatar
JVJaz
I did use the outside button so I'll need to use the inside button from now on. Thanks.
Old Mar 30, 2015 | 12:17 PM
Woodson's Avatar
Woodson
Or fob...
Old Mar 30, 2015 | 12:18 PM
JVJaz's Avatar
JVJaz
Or fob...
Old Jul 5, 2015 | 11:34 PM
lottavettes's Avatar
lottavettes
I just had my screen go blank. I did go into the trunk first when I left my second last place. The last time I started it I opened the door first and I was getting vibrating pixels etc for ten minutes and ten minutes later it was OK.
I guess I'll go to El Dealer in the morning and see about software updates. Also, will I have to leave the car or will they remove the whole unit and let me go with the car till it's fixed?
To Balnk DIC Solution
