Front end
Old Mar 26, 2015 | 07:25 PM
mikeg58's Avatar
mikeg58
Default Front end
It's been a long winter . Does anyone notice when taking the car out in cold weather that when Turing the wheel while backing out from driveway it feels like the tires are rubbing the wheel well . But when it warms up it seems to go away.
Old Mar 26, 2015 | 07:29 PM
PUGPROUD's Avatar
PUGPROUD
Normal. Low profile tire sidewall rubbing will occur at very low speed turning of wheels.
Old Mar 26, 2015 | 07:38 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
Tire scrubbing in tight turns. Normal in any temps.
Old Mar 26, 2015 | 07:53 PM
mpuzach's Avatar
mpuzach
What you're experiencing is the front tires scrubbing against the pavement. It's completely normal.
Old Mar 26, 2015 | 07:54 PM
VETJAZZ's Avatar
VETJAZZ
Check your owner's manual - 10-62
Tire Chatter/Hop
When driving at slow speeds and in
very tight turns, the vehicle may
have tire chatter/hop. This is normal
and the vehicle does not require
service.
Also do a search - tire hop or Ackerman effect. Dozens of threads
Old Mar 26, 2015 | 07:55 PM
ArcticC7's Avatar
ArcticC7
It's normal for this car. No other Corvette I have owned ever did it to the extent of the C7. Annoying as hell.
Old Mar 26, 2015 | 08:31 PM
doug doo wop's Avatar
doug doo wop
The dealer who sells these cars should tell tell the buyer about wheel hop along with the summer tires that you can't drive in the winter;both are a pain in the butt!
Old Mar 26, 2015 | 08:38 PM
motomanvette's Avatar
motomanvette
Be careful not to crack those tires.
Old Mar 26, 2015 | 09:21 PM
Steve_R's Avatar
Steve_R
My C6 was worse than my C7. If it's so annoying don't turn as sharp and it won't happen.
Old Mar 26, 2015 | 09:29 PM
EcoBrick Bob's Avatar
EcoBrick Bob
Dazed Confused & Verklemp
Mine does it every time I back out of my drive. The temp is always over 60 and the asphalt often is way over 120 here in SW Florida.
Old Mar 27, 2015 | 05:50 PM
mikeg58's Avatar
mikeg58
Thanks for the. Info
Old Mar 27, 2015 | 10:56 PM
traronf's Avatar
traronf
Excellent explanation here:
http://blog.patmcgrathchevyland.com/...ette-stingray/
Old Mar 27, 2015 | 11:06 PM
Bill B 1's Avatar
Bill B 1
It happens to me almost every time I back out of my driveway. Even after 14000 miles it still takes me by surprise sometimes and sends a shock wave through my senses! It'll be interesting to see if my new Bridgestone tires do the same thing.
Old Mar 28, 2015 | 12:57 AM
WelderGuy's Avatar
WelderGuy
The video in post 12 is correct, but the C7 uses a non-Ackermann design to get better turning performance. Therefore the resulting wheel hop should really be called the "Non-Ackermann Effect".
Why would you blame poor Ackermann for the problem when the engineers didn't follow his advice? That would be like calling the committee formed to investigate **** and Communist sympathizers the House American Activities Committee.
Old Dec 11, 2019 | 08:40 PM
Grand_Wish's Avatar
Grand_Wish
My gt350 did it as well so I guess I am kind of use to it.
Old Dec 11, 2019 | 11:33 PM
Avanti's Avatar
Avanti
Sure, mine does it anytime I'm at full lock, or nearly so.
To Front end
