PDR Editing Help
Editing Problem: If I use MovieMaker or AVS Editor, the file created after editing out the non-run time at the beginning and end of the PDR recording (it was an autocross so no defined start or finish), the Cosworth software says the file is not recognizable. This is using a new file name, or the original filename, original location on SD card or on hard drive. It plays fine with any normal software. Thoughts?
Also, is there a way to use the Cosworth software to eliminate the overlays like 0-60, etc?
Thanks in advance
