Chime volume setting
Old Apr 2, 2015 | 03:45 PM
iclick's Avatar
iclick
Default Chime volume setting
There is a section in Infotainment settings to adjust your chime volume, but mine isn't functional. There is a scale with no slider for adjustment. Has anyone else noticed this? I wonder if this will be fixed in the recent software update, which I'm doing next week.
Old Apr 2, 2015 | 04:47 PM
VINDIC8R's Avatar
VINDIC8R
Banned Scam/Spammer
Old Apr 3, 2015 | 01:35 PM
iclick's Avatar
iclick
Nobody has seen this setting or tried to adjust it? Did a search and found nothing.
Old Apr 3, 2015 | 06:15 PM
Oskee's Avatar
Oskee
Veteran: Marine Corps
As far as I know there is really no chime volume control in the infotainment (sliding scale) . When you get to the chime volume control you either turn it off or on . I had mine on for awhile and it bugged me so I turned it off.
2015 Z06 A8
Old Apr 3, 2015 | 08:22 PM
Baer383's Avatar
Baer383
I adjusted mine all the way down it works great (mine is a 15)
Old Apr 4, 2015 | 08:25 AM
iclick's Avatar
iclick
I see the horizontal scale but no slider, and no way to change the chime volume in any way--not even to turn it off.
Old Apr 4, 2015 | 08:29 AM
Baer383's Avatar
Baer383
I have the scale with a + and - button at each end with the key on car off drivers door open to hear the chime keep pressing the - key and my volume went down
Old Apr 4, 2015 | 08:40 AM
MikeyTX's Avatar
MikeyTX
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Old Apr 4, 2015 | 12:49 PM
iclick's Avatar
iclick
I now see how it works. Mine was apparently already set to the minimum, and hitting + makes a red sliding bar appear that moves further to the right as you repeat. However, I can hear no change in volume regardless of the bar's position. I guess I'll just have to get used to the obnoxious thing.
Old Mar 14, 2023 | 11:23 AM
AFRJacket's Avatar
AFRJacket
My chime volume all of a sudden started blasting loud. Also, the exit light timer is running at longest time. Neither allow me to functionally adjust down or off despite allowing me to change settings visually in menus.
I will be bringing this up at upcoming oil change. Wiring issue??? Fuse??? I'm not a mechanic. No idea, just strange and annoying!
To Chime volume setting
