A8 Z51-testing out the launch control
Yes, I had read about the launch control and tried it, but I was totally uncomfortable really making an effort to do as the owners manual stated. On this run, I only half way tried to do it the proper way. On my past cars, unless they had drag radials (which I did John Force burnouts to really heat them up and had real good success), I usually launched off idle or at 1K rpms at the most. Most of my cars also had bad wheel hop issues (2005 GTO, 2009 G8 GXP, and two 2013 Mustang GTs) where I had to be real careful launching the cars.
This launch control was as foreign to me as is having a date with Kate Upton.
I've read the instruction manual time after time after time. Be in while soaking in the tub or taking a crap, I've read it more than I should've read it. Perhaps I was missing the little things, however I think I just didn't buy into the launch control working that well.
Tonight I drove from Houston to Lake Charles to see if I could double my money (yes I did) and on the way there is a place with a 70 mph speed limit and very little traffic to try using the launch control by the book.
OK, the book states to floor the brake in a panic brake mode, in other words, my 250 pounds standing on the brake while flooring the gas pedal. Well, it just wasn't that simple. Here's proof. You can hear me mumble being in a panic brake mode during the video. You can also hear the car working against the brakes.
I was happy with the time of 3.8, however I wasn't happy at all when I crept forward. At the track, you can't creep forward that far, and this is all about practice for making a return trip to the track. Instead of flooring the go pedal like the book stated, this seemed to work better when I gradually raised the rpms, the let off the brake.
As it was a nice day, minimal traffic around, I decided to try it again. This time I worked at gradually increasing the rpms and this time I only crept forward once or twice. The end results were a lot better than the prior run.
I'm very happy with the 3.6 and I can't help but wonder what the 3.6 would be without being in a hot car, warming up the tires a bit, and launching from a well prepared launch area.
Hopefully this experiments will help out some of the other guys who may need to take a quick look at what I did.
Lastly, I know .1 quicker in a 60' should be close to .2 in the quarter, however I don't know the racers math when one goes from 3.91 to 3.6 from 0 to 60. Hopefully this could mean going from an 11.91 to 11.6X. Wishful thinking? Maybe, but one can always hope.
You really have to stand on the brakes I guess?
To much traffic and law enforcement in my area to really try it again.
I need to find an empty parking lot somewhere.
For me, just easier to roll in to the throttle on the street.
Even with TC ON the car will spin the tires and lose valuable time if I go full throttle from a dead stop.
Maybe in 90 degree weather it will hook at full throttle?
Eventually I'll get up to a better prepped track. However, after all this, the "launch control" seems to me to be against every drag principle I know. And the guys I know who have used it just burn like crazy.
Just my 2 cents.
11 91 - YouTube
That being said, your times are in line with the best I've seen for a non-Z at 3.60 seconds. Don't really think launch control will help you at all - you've already nailed it my friend
But it seemed to work the other day. No warming up tires, just accelerating from the shoulder of a road, no track prep. Perhaps it's just something we have to see successfully done by doing it in order to buy in to it.
From the description of launch control with an auto it seems that flooring the brake & throttle must turn the mode on and if you don't do it exactly in the right sequence you'll be launching at 5000 rpm.
