Jumping a C7
Old Apr 13, 2015 | 05:18 PM
rlhtroy@aol.com's Avatar
rlhtroy@aol.com
Default Jumping a C7
Hey guys, I just had an interesting experience. I am in Myrtle Beach and decided to drive my C7 here. The first night I accidentally put the car in neutral rather than park. You guested it, in the morning the car was dead.
We called AAA and their tech guy seemed OK and started the car. Shortly after he left. All instruments were gone... nothing. I just got the car back
from the local Chevy dealer who told me it had a power surge and everything have to be reprogramed. Needless to say not under warranty with only 2000 miles. $100 later everything is OK. I don't believe the tech guy did anything wrong. What happened?
Old Apr 13, 2015 | 05:29 PM
Zymurgy's Avatar
Zymurgy
Moderator
The AAA tech guy probably did something wrong. Did he jump it using the battery terminals in the hatch area?
Old Apr 13, 2015 | 05:32 PM
rlhtroy@aol.com
Yes he was in the hatch area.
Old Apr 13, 2015 | 05:38 PM
C7 BOB's Avatar
C7 BOB
I was hoping you were going tell us how you drove your C7 up a ramp and over a school bus.
Old Apr 13, 2015 | 05:59 PM
TEXHAWK0's Avatar
TEXHAWK0
Was the ignition off when he was connecting the jumper cables?
The negative cables should be connected last.
Old Apr 13, 2015 | 06:05 PM
Zymurgy's Avatar
Zymurgy
Moderator
That's not what the Owners Manual says (at least the 2014 version):
1. Discharged Battery Positive (+) Terminal
2. Discharged Battery Negative (−) Terminal
3. Good Battery Negative (−) Terminal
4. Good Battery Positive (+) Terminal
Old Apr 13, 2015 | 07:48 PM
W88fixer's Avatar
W88fixer
Hi John, the owner’s manual does specify jump starting from the battery. Any issue if one jumped from the terminals under the hood?
My understanding was that underhood was OK for both jump starting as well as charging. Right or wrong? Don
Old Apr 13, 2015 | 08:17 PM
alanancy's Avatar
alanancy
Planning to go to Myrtle Beach next month. Hope you at least had a good time.
Old Apr 13, 2015 | 10:23 PM
OVERULD's Avatar
OVERULD
St. Jude Donor '16
I presume it was the electric parking brake holding the car that caused the battery to go dead?
BJ
Old Apr 13, 2015 | 11:14 PM
Zymurgy's Avatar
Zymurgy
Moderator
I realize that and that is why I asked if the tech did that.
Old Apr 13, 2015 | 11:17 PM
Zymurgy's Avatar
Zymurgy
Moderator
BJ
That does not seem to be likely. I have left the e-brake on mine for 3 weeks straight with no ill effects. Surely the e-brake is designed so that it is not "energized" continuously when applied.
Old Apr 13, 2015 | 11:27 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Athough I have an M7, I always leave my car in Neutral. Once the brake engages there is no longer power needed to keep it engaged.
Old Apr 14, 2015 | 09:43 AM
Bruiser2012's Avatar
Bruiser2012
Default Me too!
I was thinking Dukes of Hazard and was excited about some pictures
-Bob
Old Apr 14, 2015 | 04:07 PM
TEXHAWK0's Avatar
TEXHAWK0
What you read is just the list of terminals in the diagram, not the order in which they are connected.
The negative terminal on the dead battery should always be connected last to avoid sparks...
Read the detailed sequence in the manual Steps 7 through 10.
Old Apr 14, 2015 | 04:13 PM
TEXHAWK0's Avatar
TEXHAWK0
My 2011 Camaro battery is under the spare tire in the trunk, and the owner's manual shows jumping the car from the terminals under the hood, so if it is alright for the Camaro, I would think it would be alright on the Corvette.
Just make sure everything, including the radio, is turned off before connecting cables.
Old Apr 14, 2015 | 04:30 PM
meyerweb's Avatar
meyerweb
This is what I'm thinking. Make sure the car is turned off when the cables are connected. Only after all four connections are made try to start the car.
I don't know why leaving the car in neutral would have anything to do with battery drain.
Old Apr 14, 2015 | 05:38 PM
TEXHAWK0's Avatar
TEXHAWK0
I was confused too because my first thought was he had a manual transmission, but since he says he did not put it in PARK, it must be an automatic.... Leaving it in neutral probably never allows the car to completely shut off.
I think manuals used to have to be in REVERSE, but GM did away with that on the C7. (I hope)
To Jumping a C7
Old Apr 14, 2015 | 08:51 PM
Zymurgy's Avatar
Zymurgy
Moderator
You are absolutely correct. Thanks for pointing that out.
Old Apr 14, 2015 | 08:54 PM
Zymurgy's Avatar
Zymurgy
Moderator
The requirement to put a manual in Reverse only applied to the first year C6 and was the origin of Dead Battery Syndrome.
Old Apr 14, 2015 | 11:01 PM
jedblanks's Avatar
jedblanks
On any battery. Dead or not. Mechanic taught me the pneumonic RENIP. Stands for remove negative install positive.
In other words when removing battery disconnect negative first and when installing a battery connect positive first.
