C7 insulation?
Old Apr 17, 2015 | 10:17 AM
mcr98's Avatar
mcr98
Cruising
Default C7 insulation?
does anybody know if there are any c7 insulation kits available yet, I've called and emailed crazy cowboy but have not got a response so I'm looking for someone else thanks for any help
Old Apr 17, 2015 | 10:32 AM
chipsvette06's Avatar
chipsvette06
Yes. Try a search.
Old Apr 17, 2015 | 10:36 AM
C8Jake's Avatar
C8Jake
$60 diy Rattletrap Xtreme
Old Apr 17, 2015 | 10:40 AM
Keith N's Avatar
Keith N
Just do it yourself, it's an easy mod and a lot cheaper.
Old Apr 17, 2015 | 10:41 AM
Spinny's Avatar
Spinny
Check out BLOKIT from TKO, a forum vendor. I have used this product to great advantage on both my Vettes.
Old Apr 17, 2015 | 11:05 AM
Larry/car's Avatar
Larry/car
My only comment; people want quiet yet have NPP or after market exhaust? I have stock exhaust and don't need insulation kit (quiet enough).
Old Apr 17, 2015 | 11:09 AM
mcr98's Avatar
mcr98
Cruising
your comment doesn't help me much or anyone else for that matter but I want to eliminate some of the useless road noise that nobody needs to here thanks
Old Apr 17, 2015 | 11:51 AM
Keith N's Avatar
Keith N
As C7 Jake posted, $62 shipped for FatMat 25 sq. ft. roll from Amazon.com. This will greatly reduce road and tire noise in the cabin.
Old Apr 17, 2015 | 02:37 PM
crawfish333's Avatar
crawfish333
CI 6-7 & 9 Veteran
Not the exhaust that bothers most people, it is road noise. Especially on highways that have a gravel paving.
Old Apr 17, 2015 | 05:16 PM
beepster's Avatar
beepster
Yup, its called "chip and seal" and is all the rage now in TX. The driviing surface is horrible and delaminates after only a few months. Most county/city road authorities are using it now because it is "cost effective". Another example of your tax dollars at work...
Old Apr 17, 2015 | 05:59 PM
Ernest_T's Avatar
Ernest_T
You equate the sweet exhaust note of the Stingray to the roaring tire noise of a run flat tire?
Old Apr 17, 2015 | 06:22 PM
speedlink's Avatar
speedlink
Old Apr 17, 2015 | 08:46 PM
ffr1352's Avatar
ffr1352
I used peel n seal from Lowes behind the seats and in the cargo area, then some frost king foam insulation also with foil backing from lowes and then the block it matts available from forum vendor TKO. Very pleased with reduced tire road noise... it is now the way it should have been delivered from the factory.
Old Apr 18, 2015 | 12:13 AM
nmvettec7's Avatar
nmvettec7
C7 Jake has one of the nicest installations of sound deadening material I have seen. His installation although a DIY install, looks extremely professional IMO.
I have to agree that on roads that have allot of exposed aggregate to the road surface, the interior noise level is not comforting. On a smooth road surface, I have no complaints.
Old Apr 18, 2015 | 12:25 AM
HAD2HAV2's Avatar
HAD2HAV2
When I enter I-77 in North Charlotte in my 2015 the road is asphalt over concrete. I have to turn up the stereo because of the rear wheel noise. Will try this insulation some time this year.
As soon as I can figure out how to pull back the carpet.
Old Apr 18, 2015 | 10:58 AM
HDBADDOG55's Avatar
HDBADDOG55
Default Glen e FatMat Sound Deadening Mod
Old Apr 18, 2015 | 07:28 PM
EcoBrick Bob's Avatar
EcoBrick Bob
Dazed Confused & Verklemp
Rattle Trap is a thicker version of Fat Mat. Fat Mat also makes Mega Mat which is rubber, to go over either Fat Mat or Rattle Trap. The 2 together are really great. I have both installed in my Z51 both behind the seats and in the entire rear compartment. Highly recommend.
To C7 insulation?
