How to determine MSRC?
Old Apr 20, 2015 | 01:23 AM
jriley9922's Avatar
jriley9922
Default How to determine MSRC?
If an original owner didn't save the window sticker and they're not corvette freaks like us... How can you determine if it has magnetic ride?
It is a z51... 2014... And loaded 3lt. But how would you confirm it's mag ride or not?
Old Apr 20, 2015 | 03:34 AM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
You can get a window sticker from the corvette museum.
look at the top of front shocks, under hood, if it has a cable coming out they are mag shocks
Old Apr 20, 2015 | 03:59 AM
Along4theRide's Avatar
Along4theRide
CF Old Timer
St. Jude Donor '14-'15-'16
Mag ride is standard on Z51.
Old Apr 20, 2015 | 04:51 AM
Glen e's Avatar
Glen e
No its not.....
Old Apr 20, 2015 | 07:18 AM
mksz51's Avatar
mksz51
Wrong - must have Z51 to be able to order mag ride.
Old Apr 20, 2015 | 07:24 AM
laborsmith's Avatar
laborsmith
Must have Z51 to order mag ride but not every Z51 came with it.
Every Chevy has a decal showing each RPO including options installed on that individual Chevy.
Laborsmith
Old Apr 20, 2015 | 07:26 AM
MikeC4C5C6...C7's Avatar
MikeC4C5C6...C7
If your Z51 has magnetic selective ride control you should be able to notice a difference in the ride between Tour, Sport and Track. If you aren't on a bumpy road, cycle through those three settings while turning the wheel sharply back and forth--if you have MSRC you will be able to tell the three different suspension settings. Really.
Have fun!
Old Apr 20, 2015 | 07:34 AM
Kenafin's Avatar
Kenafin
Laborsmith
On the decal look for RPO code FE4 - that is the one which indicates magnetic ride control
Old Apr 20, 2015 | 08:10 AM
norlem's Avatar
norlem
Default mag ride
Those with mag ride have black shocks and those without have yellow. Learned that at Spring Mountain.
Old Apr 20, 2015 | 08:31 AM
mjw930's Avatar
mjw930
To be concise, here are the ways to determine if you have MRSC.
1. Under the hood the top of the shocks will have a small black wire coming out of the top of the shock / shock mount.
2. MRSC shocks are black, standard shocks are yellow. Best seen from the rear, just look under the car.
3. FE4 code on the RPO sticker under the carpet in the rear
4. Go into Track mode and double press the traction control button, if additional modes show up such as wet, dry, sport 1, sport 2 and race then you have MRSC.
Old Apr 20, 2015 | 08:51 AM
jriley9922's Avatar
jriley9922
Thanks guys! the black vs. yellow shocks makes it really easy... that kind of info is exactly what i was hoping to obtain.
To How to determine MSRC?
