Help needed with Remote Keyless Entry.
So the C7 showed up Tuesday, and I was thrilled. Two days before that I finally entered the modern era and bought my first smart phone, a Galaxy Note 4. Between the two I think my mind will blow up any second.
Anyhow, simple question which I just can't figure out on the Corvette. (This is my first car that didn't just use a plain old key!)
And yes, I have read the manual numerous times on the subject, done many searches and read the posts on this forum, viewed the help videos on Youtube time and time again........and I just don't get it. I'm not seeing the forest for the trees.
All I want to do is set up the car so that when I walk away from it I know 100% that it's locked, that's all. Sounds simple enough, but apparently I am so stupid or missing something. I have tried configuring all combinations in the car......through the settings menu but can't get it to work the way I want.
I don't want to push the button on the remote to lock it, I just want to walk away and have it lock, and it would be nice to hear the horn beep or see the lights flash (or both) to confirm it's locked also.
Any simple (or complicated, I don't care) solution to this would be greatly appreciated.
This seemingly simple setup is driving me nuts! (And here I thought setting up the seat memory and entry/exit was going to be the hard part.That was a piece of cake!)
Any help would be greatly appreciated.
Alaskapaul
Thanks so much. Apparently I never scrolled down far enough on the menue to see the setting I needed. I knew there had to be a simple answer. Again, forest and trees stuff.
Thanks again, worked like a champ and exactly as I had wanted.
Alaskapaul
