Lousy deck latch
Old Apr 26, 2015 | 11:15 AM
Two Toes's Avatar
Two Toes
Default Lousy deck latch
I have very few complaints about our 2015 Coupe, but the deck latch is one. After having the "pull down latch" in our C6. I find it a real pain to have to open a door to close the hatch. Yes, I can slam it, then push on the paint to latch it. NOW, I see the 2016 has "Power-cinch feature for coupe hatch and convertible trunk latches". I guess the BS offered by GM about weight is no longer an issue! Will this feature become available for the previous C7's?
Old Apr 26, 2015 | 11:21 AM
Elegant1's Avatar
Elegant1
No it was said that retrofitting the power latch would be to hard to do. ALL they needed to do was index the side glass the same exact way it already does when opening a passenger door except do it for for the rear hatch door as well. Try putting your side glass down 1/4 inch on both doors and go back and close the hatch. Then see for yourself how simple of a fix this could have been.
Old Apr 26, 2015 | 11:24 AM
thrilled's Avatar
thrilled
On my 2014 c7 it don't go down easy.But if I have 1 or both doors open then no problem.
Old Apr 26, 2015 | 11:30 AM
zbrett's Avatar
zbrett
https://www.corvetteforum.com/forums...-standard.html
Old Apr 26, 2015 | 11:34 AM
nmvettec7's Avatar
nmvettec7
The C7 appears to be a well sealed vehicle. I believe that most of us owners who own a 2014 or 2015 C7 have experienced the same result when trying to close the rear hatch.
Since the car is so well sealed, closing the hatch creates air pressure within the cabin thus having a hard time to close the hatch entirely.
As others have suggested having the car door open just abit or window down 1/4 inch, you will not experience this problem.
Yes it is a PITA no doubt, but hey we know the C7 is well sealed.
Look at the positives of the situation.
Old Apr 26, 2015 | 11:49 AM
dvilin's Avatar
dvilin
Slam it shut and it is done, not sure what the big deal is. The power hatch on the C6 was not 100% either. Minor irritation.
Old Apr 26, 2015 | 11:57 AM
TEXHAWK0's Avatar
TEXHAWK0
All they really had to do was make the automatic vent big enough.
High tech vent opens and closes by itself, but worthless if it does not work.
Old Apr 26, 2015 | 12:18 PM
hawkgfr's Avatar
hawkgfr
Exactly....and I doubt the "power" cinch will work any better than it did on the 4 c6's I had....which was about half the time so then you end up slamming it there too.
I hate they moved the hidden button hatch open button the most lol...and changed the shape. I keep trying to use the round area that has one of the tag lights..
Old Apr 26, 2015 | 12:26 PM
Joy c7's Avatar
Joy c7
Just use a mirco fiber cloth and gentley push down works every time. No slamming..
LEJ ZO6's Avatar
LEJ ZO6
Which C6 Corvettes had an auto pull down latch ?
My wife had a 2007 convertible that didn't have it and I have a 2008 ZO6 that doesn't have it.
I didn't realize it was even offered on the C6.
Old Apr 26, 2015 | 02:24 PM
Cathouse's Avatar
Cathouse
My 2009 Z06 has the power deck latch mechanism.
Sometimes when you drop the deck to close it, it works and you can easily hear it. Sometimes it doesn't engage, as mentioned above, and you have to press down to lock it.
Cheers!
Old Apr 26, 2015 | 02:32 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Never been a big deal for me and the hatch closes with little effort and without having to roll down windows
Old Apr 26, 2015 | 02:52 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
For some of us, slamming doesn't work! I've had my C7 since October 2013. I can slam from high or low with a lot or a little force, it will not latch! I have tried adjusting the hatch stops and lubed the latch as well. I have also watched the memory wire vent open and close "as designed" still no help (you can watch it though the large hole behind the license plate.) Nothing helps. Early on I tried pressing to latch and watched the hatch frame bend! Now I always keep a door open. In fact I can stand behind an open door and it closes with little force from the side!
Happiness is a tight Vette!
Old Apr 26, 2015 | 03:47 PM
iclick's Avatar
iclick
This is the biggest oversight in the car's design, IMO. Like JerryU, mine won't latch, period--even when I slam the hatch with great force. Yes, I can press it down once it partially latches, but I don't like the idea of repeatedly applying force to a small painted area. So, I just open a door, which is never convenient, especially if I don't think about it before closing the hatch, which is usually the case. Maybe after I own the car for a while I'll get into some sort of rhythm.
I wonder if the vent hole behind the license plate could be enlarged. A simple software update could enable window indexing, so maybe if we complain enough they'll listen.
Old Apr 26, 2015 | 03:51 PM
slickstick's Avatar
slickstick
Considering my 2005 has it, probably all of them and you just never noticed.
Old Apr 26, 2015 | 03:52 PM
slickstick's Avatar
slickstick
Sounds like based on all these issues there should be a recall to add the latch motor.
Old Apr 26, 2015 | 04:27 PM
Formula52's Avatar
Formula52
To Lousy deck latch
Old Apr 26, 2015 | 04:40 PM
JerryU's Avatar
JerryU
The problem was known early on as it was a poster in late 2013 as I recall that was told at Museum Delivery not to press on the center of the hatch frame to latch as there had been reports of paint cracking! They were told to press with two hands on the peaks near the window edges. A large forum dealer said 20% of the cars he sold had paid cracking from bending!
I have been at this for 1 ½ years and it helps sharpen my short term memory to remember the sequence! Usually you’re getting into the hatch when entering or leaving the car. If leaving just have to remember to keep the door open before closing the hatch and if getting in, open the door before closing the hatch. As mentioned in a previous post, I can stand behind the open door and close the hatch from the side with very little force!
Old Apr 26, 2015 | 08:35 PM
stevestig's Avatar
stevestig
Tadge was asked and replied to this at the Bash. From what he said there were a couple of problems with adding indexing to resolve this issue:
1. There are federal "pinch" laws (who says we don't have too much government ) and they can only index the windows down so far to comply with the law. It is such a small amount (I think he said 4mm, but don't quote me) that it didn't relieve enough pressure to make closing easy.
2. If its raining and you opened up the hatch, there was the potential for dumping water on the passenger when the window indexed. Probably not a wanted side effect.
Old Apr 26, 2015 | 08:52 PM
JerryU's Avatar
JerryU
Thanks for the feedback. Can understand the "pinch" of a child's finger being an issue. Thought that was lawyers did not realize the government got involved! Hard to argue in court that a 3 year old should know better!
Keeping the door open to have the hatch latch workaround, also using a finger on my left hand to hold in the memory button while buckling the seat belt with my right hand and turning the steering wheel less when it's cold to avoid excess "tire chatter," are easy to do and not really that much of an issue with a great car. They made so many changes in this car from the C6 can accept these first years issues. Glad they are fixing for the 2016.
