Adding Coolant
Old Apr 30, 2015 | 09:50 AM
Stingray Al's Avatar
Stingray Al
Default Adding Coolant
I checked the overflow resivor. It is about 1/2 full.
Question: How much coolant do I add? Until it is up to the top of the resivor ?
Al
Old Apr 30, 2015 | 10:06 AM
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
Not an expert on the C7 as I don't have mine yet but on most cars it should be less than full when cold to allow for expansion when hot. Don't overfill or you will find coolant on the floor of your garage or driveway. Check the manual for proper levels.
Old Apr 30, 2015 | 10:08 AM
TEXHAWK0's Avatar
TEXHAWK0
If you look closely on the front of the reservoir inline with the filler cap, there is a vertical arrow pointing down to a line, that is the full line. About an inch below the top seam where it changes from black to clear.
Old Apr 30, 2015 | 12:11 PM
Zymurgy's Avatar
Zymurgy
Moderator
Checking Coolant
The vehicle must be on a level
surface when checking the coolant
level.
Check to see if coolant is visible in
the coolant surge tank. If the coolant
inside the coolant surge tank is
boiling, do not do anything else until
it cools down. If coolant is visible
but the coolant level is not at or
above the cold fill line, add a
mixture of 40% DEX-COOL coolant
and 60% clean, drinkable water at
the coolant recovery tank, but be
sure the cooling system is cool
before this is done. See Cooling
System (Engine) on page 10-20 or
Cooling System (Aero Panel) on
page 10-21.
The engine coolant surge tank is
toward the rear of the engine
compartment on the passenger side
of the vehicle. See Engine
Compartment Overview on
page 10-7.
When the engine is cold, the coolant
level should be at the cold fill line on
When the engine is hot, the level
could be higher than the cold fill
line. If the coolant is below the cold
fill line when the engine is hot, there
could be a leak in the cooling
system.
If the coolant is low, add the coolant
or take the vehicle to a dealer for
service.
How to Add Coolant to the
Coolant Surge Tank
Warning
You can be burned if you spill
coolant on hot engine parts.
Coolant contains ethylene glycol
and it will burn if the engine parts
are hot enough. Do not spill
coolant on a hot engine.
Warning
Steam and scalding liquids from a
hot cooling system can blow out
and burn you badly. Never turn
the cap when the cooling system,
including the surge tank pressure
cap, is hot. Wait for the cooling
system and surge tank pressure
cap to cool.
If coolant is needed, add the proper
DEX-COOL coolant mixture directly
to the surge tank, but be sure the
cooling system is cool before this
is done.
1. When the cooling system,
including the coolant surge tank
pressure cap and upper radiator
hose, is no longer hot, remove
the pressure cap.
Turn the pressure cap slowly
counterclockwise about
one-quarter turn and then stop.
If a hiss is heard, wait for that to
stop. A hiss means there is still
some pressure left.
2. Keep turning the pressure cap
slowly, and remove it.
3. Fill the coolant surge tank with
the proper DEX-COOL coolant
mixture until the level inside
stabilizes at the cold fill line on
the front of the surge tank.
4. With the coolant surge tank
pressure cap off, start the
engine and let it run until the
upper radiator hose can be felt
getting hot. Any time during this
procedure, watch out for the
engine cooling fan.
By this time, the coolant level
may be lower. If the level is
lower, add more of the proper
mixture to the coolant surge tank
until the level stabilizes at the
cold fill line on the coolant
surge tank.
5. Replace the pressure cap tightly.
Check the level in the surge tank
when the system has cooled
down. If the coolant is not at the
proper level, repeat Steps 14,
then reinstall the pressure cap.
If the coolant is not at the proper
level when the system cools
down again, see the dealer.
To Adding Coolant
