I've recorded a bunch of songs to a USB memory stick. When I play it in my 2015 Z06, it only plays the first song. It will play it over and over if I let it. If I hit the browse button, the screen shows all the music on the memory stick, and will play whichever I choose, but refuses to advance to the next song, instead playing the selected song over and over. It does the same thing when I use voice command, (very cool, by the way!). It will happily find and play the song I request, but refuses to advance to the next song, whether by the same artist, or a different one.
These same memory sticks play fine in my other cars - they start with the first song, play through them all, then go back to the first song.
I swear I haven't hit a "repeat" button - I don't even think there is a repeat button.
What am I doing wrong?
Make sure your drive is formatted FAT32. Create a folder for your music and put all the songs in the folder. When you bring up the folder hit "play all". You can title your folder whatever you want. It probably thinks each song is a separate folder.
I had that issue as well, I ended up deleting the songs it would loop on (about 10 out of 3000) and it has worked fine since.
I had the same issue, but Browse just showed the one song. The good people here told me about the need for FAT32 (which is in the manual, but I missed it).
