Where's the handle?
I like the push button door release just fine. The only downside I see is in an emergency, without power, people aren't going to automatically know how to open the door. No one will remember that lever on the floor when they're half panicked after a crash of some sort. Muscle memory takes over, and your muscles have never used that floor release.
Not a common problem, but it could be an issue in a few rare cases.
Cars with manual door handles can do this, too. They just need a micro-switch built into the mechanism.
Corvette needs one of those safety pamphlets like the airlines put in the seat pocket in front of you. Before driving, the car could play a recording while the driver does goofy hand gestures that attempt to explain how to use things like the seatbelts use emergency door handles. Of course passengers will still die because they are facebooking instead of paying attention.
Seriously, it's just the evolution of the car. As long as the electrical releases work just fine, then it is a
addition and may even save some weight on the vehicle.
No worries; they work fine as they did on my C6 too. Only concern is some extra "clicking" of the unlock switch sometimes upon opening the locked driver's door if your fob is close, like, in your right hand pocket.
Like why they moved the headlight dimmer switch to the turn signal lever combo? Occasionally run out of hands driving through turns and the oncoming car gets blasted with my high beams.
