New Engine Replacement experience
Old May 24, 2015 | 03:35 AM
Seannyc's Avatar
Seannyc
Default New Engine Replacement experience
Anyone on here that had there c7 engine need a replacement and how did everything go any other problems after that what was the time waitin for the replacement
Dealer called me and said 3 valves are out and pistons are kissing the valves may need replacement If there is bottom end damage ..I kinda like the idear of just rebuilding mind if there isn't internal damage keeping matching number and pretty sure noting will go wrong if they fix everything . A new engine I think will hurt me in the long run what you guys think
Old May 24, 2015 | 08:19 AM
rkhegler's Avatar
rkhegler
Dealer called me and said 3 valves are out and pistons are kissing the valves may need replacement If there is bottom end damage ..I kinda like the idea of just rebuilding mind if there isn't internal damage keeping matching number and pretty sure noting will go wrong if they fix everything . A new engine I think will hurt me in the long run what you guys think
What did you do to damage the engine?
Old May 24, 2015 | 08:50 AM
b4i4getit's Avatar
b4i4getit
Matching numbers won't matter. This car is not a collectible since they make too many. I would also say that since a dealership generally is not in the business of rebuilding engines your likelihood of a successful build is not that high. A new engine that went through the complete build process at the factory with all the automated checks is probably a more reliable engine.
Old May 24, 2015 | 08:52 AM
BRCC's Avatar
BRCC
Unless you plan on keeping the car for 30 or 40 years, I would suggest you let them replace the engine instead of a rebuild. Factory warranty replacement does not show up on Carfax. GMVIS will show both rebuild and or replacement.
I had an engine replacement on a 14 and when traded in it was a certified GM car with no indication on Carfax of a problem.
Basically I had multiple problems first Torque Tube, then main bearings so engine replacement, dealer told me if I wanted a 15 I would get a good deal and he lived up to his word so now I have a 15.
Old May 24, 2015 | 08:56 AM
grandpawmoses's Avatar
grandpawmoses
I agree. A rebuild, at best, could only be as good as a new engine.
Old May 24, 2015 | 09:55 AM
Red C8 of Jax's Avatar
Red C8 of Jax
I don't like the dealer changing my oil much less rebuilding my engine. Get a new engine from the factory. Hopefully the dealer can install it correctly and you will have no further problems.
Old May 24, 2015 | 11:38 AM
Elegant1's Avatar
Elegant1
Tell GM to kiss your A$$ go for a buyback. Thats what they get for making faulty engines. Make them exchange the whole car they know darn well they have a bunch of faulty motors out there. Let me guess about 8K miles on the car now?
Old May 24, 2015 | 12:18 PM
beepster's Avatar
beepster
After that experience, I would not want the car and would be ready to move on.....
Old May 24, 2015 | 01:01 PM
aj98's Avatar
aj98
what you dnt know is if there are little metal shards that may not get 'cleaned out' during a rebuild.
its under warranty - replace it.
btw, my c-5 had the engine replaced relatively earlty in its life. did not harm it's value.
Old May 24, 2015 | 01:21 PM
Seannyc's Avatar
Seannyc
Noting car is stock 1200 miles they told me this happens defects
Old May 24, 2015 | 01:24 PM
Seannyc's Avatar
Seannyc
Only 1200 miles barley even drived my car
Old May 24, 2015 | 01:25 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
There is no such thing as numbers matching any more. Unless your state's lemon law applies you really can't demand they take it back or exchange it for a new one. Get the new engine and drive it.
Old May 24, 2015 | 01:27 PM
Seannyc's Avatar
Seannyc
I would go for the new engine if it doesn't harm my trade in value cuz from there I would just get the z06 lol thanks guys for the info
Old May 24, 2015 | 02:16 PM
rkhegler's Avatar
rkhegler
I would deliver the car to the factory on a truck and demand a new vehicle. Have the local news media meet you at the factory door to film your complaint about the engine. The major media outlets will pick it up from their affiliates. That should get their attention.
Old May 24, 2015 | 02:50 PM
Seannyc's Avatar
Seannyc
They will probley just leave me a engine at the door lol
Old May 24, 2015 | 03:27 PM
sanantguy's Avatar
sanantguy
matching numbers. hahaha what do you think it is a 67' or something.
Old May 24, 2015 | 03:28 PM
sanantguy's Avatar
sanantguy
No, no you wouldn't.
To New Engine Replacement experience
Old May 24, 2015 | 03:44 PM
Seannyc's Avatar
Seannyc
No? Ain't tryin to collect it don't wanna lose value on it when I trade it why should my car lose value cuz there defects on the engine so whys that funny lol
Old May 24, 2015 | 03:54 PM
meyerweb's Avatar
meyerweb
You're likely to get a better engine direct from GM that from a dealer mechanic. This isn't something dealer mechanics get a lot of experience doing.
OTOH, it was the GM factory that screwed up in the first place....
Old May 24, 2015 | 03:57 PM
Seannyc's Avatar
Seannyc
alright looks like I'll go for the replacement
